98 civic intake
Old May 3, 2004 | 01:06 PM
djxtc65's Avatar
Default 98 civic intake
this weekend i put an intake on my lil siters civic and the check engine light came on ive put an intake on every honda ine had any one ever have this problem before
shwan
Old May 3, 2004 | 01:11 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: 98 civic intake (djxtc65)
Make sure you put the O2 sensor in its proper location on the intake
also make sure yuou didnt accidentally disconnect any of the vacuum lines on the intake manifold
Old May 3, 2004 | 01:12 PM
JDM-97CX's Avatar
Default Re: 98 civic intake (Vortech99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vortech99Si &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you put the O2 sensor in its proper location on the intake
O2 sensor in the intake? That's a good one dumbass.
Old May 3, 2004 | 01:40 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: 98 civic intake (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
O2 sensor in the intake? That's a good one dumbass.</TD></TR></TABLE>
Whats the sensor called then??
Old May 3, 2004 | 01:41 PM
JDM-97CX's Avatar
I believe it would be the MAF.
O2 sensor is in your exhaust system. It is what tells your PCM if you are running to rich or too lean.
Old May 3, 2004 | 01:42 PM
vtekstorm's Avatar
o2 on intake yea ok genius. yo the sensor he is telling u about is called the i.a.t sensor see if in all the way or if its disconnected
Old May 3, 2004 | 01:43 PM
JDM-97CX's Avatar
Default Re: 98 civic intake (vtekstorm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm &raquo;</TD></TR><TR><TD CLASS="quote">o2 on intake yea ok genius. yo the sensor he is telling u about is called the i.a.t sensor see if in all the way or if its disconnected </TD></TR></TABLE>
We allready covered that the O2 sensor is not in the intake.
Learn to read and while your at it learn to speck English as well.
Old May 3, 2004 | 01:44 PM
SOHC4life 96's Avatar
also, if that doesnt work try disconnecting the negative cable on the battery then let the car run for a few minutes to allow the ecu to adjust for the increase in air
Old May 3, 2004 | 01:48 PM
crazy eyez killa
Guest
Posts: n/a
Learn to read and while your at it learn to speck English as well.</TD></TR></TABLE>
The proper form of "you are" would have been "you're"
Learn how to write english
Heres a helpful website to help you clean up your 6th grade vocabulary
http://www.english-zone.com/verbs/your1.html
Speck = speak
Old May 3, 2004 | 01:58 PM
articbluedc5's Avatar
Did that in my Lx when I had it a while back. Reset the code, I just left mine up and it went away a month later, most likely what the other guys said a loose sensor
JDM-97CX's Avatar
Speck = speak
I hope you realize that I misspelled that on purpose right.
And in your attempt to flame me you seemed to forget that English is supposed to be capitalized.
My 6th grade vocabulary eh? I could be a jackass a place your reply into Microsoft word and see what the Flesch-Kincaid reading level is but I don't feel like wasting any more time with you.
Old May 3, 2004 | 03:50 PM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">I believe it would be the MAF.
O2 sensor is in your exhaust system. It is what tells your PCM if you are running to rich or too lean.</TD></TR></TABLE>
Nope, no mass air flow meter on a Honda, its a speed density system.
The IAT is intake air temp, but just cause its not in the intake tube, doesn't mean it'll give you a check engine light.
Best thing, pull the code for the check engine light! Auto parts stores can pull codes off of cars for free.
Diversion
Jul 21, 2009 11:57 AM
stuie08
Nov 26, 2006 07:13 PM
pinoyboy204
May 29, 2006 01:35 PM
OneSickJDMBB6
15
Jun 15, 2005 07:32 PM
OneCamIsEnough
Mar 28, 2005 08:46 AM
