Civic Overheating Problem???
Old May 3, 2004 | 01:29 AM
Saki's Avatar
Default Civic Overheating Problem???
Hi guys, I tried to search on this topic before I post, but couldn't find an answer. I have a 93 Honda Civic Hatch. The Problem I'm having with it is that it is overheating. I just replaced the thermostat and the radiator and changed all the coolant. The car is still overheating... When I first start to drive for about 2 hours, its seems to be just fine. But after the 2 hours when I'm stopped at idle the Temp starts to risel. I had the Radiator Pressure checked and everything by the Mechanic he ccouldn't give me a definite answer. Anyone ever run into a problem like this???
Thanks in Advance Guys,
Saki
Old May 3, 2004 | 03:37 AM
JimmyAtlantis's Avatar
Default Re: Civic Overheating Problem??? (Saki)
Does your fan work? I had a Mazda 626 that would overheat at idle after driving for a while. It was because the fan didn't work.
Old May 3, 2004 | 06:41 AM
2lua's Avatar
you got air in the coolant system. try to bleed the coolant system.
Old May 3, 2004 | 06:43 AM
Default Re: Civic Overheating Problem??? (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">you got air in the coolant system. try to bleed the coolant system.</TD></TR></TABLE>
You sound pretty positive. He said he already took it to a mechanic. When it was pressure tested don't you think air would have been noticed?
Old May 3, 2004 | 06:47 AM
2lua's Avatar
Default Re: Civic Overheating Problem??? (JRI94)
air can be compress too! compressing test is for checking leaks.
Old May 3, 2004 | 11:47 AM
Saki's Avatar
Hi guys. Yes the fans do work just fine. The mechanic did bleed the cooliing system and replaced the coolant. I don't think this is the problem, but could the water pump be going???
Old May 3, 2004 | 01:12 PM
jdm2k_si's Avatar
I had a similar problem to my 2000 Civic Si. I did all the same check ups you did and finally the problem was that my radiator fan switch was not working anymore. The fan worked, just not the fan switch itself. Try that.
Old May 3, 2004 | 01:15 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">
You sound pretty positive. He said he already took it to a mechanic. When it was pressure tested don't you think air would have been noticed?</TD></TR></TABLE>
You do realize how many idiotic mechanics there are in this world right?
You wouldn't notice air with a pressure test anyway.
Old May 3, 2004 | 02:31 PM
Saki's Avatar
Default Re: Civic Overheating Problem??? (jdm2k_si)
Fan Switch huh... Cool I'll check it out and let you guys know... Thanks
Old May 3, 2004 | 05:15 PM
92BlueCivic's Avatar
Fan switch can be tested by bending a paper clip and touching both ends to the contacts. If the fan kicks on then the switch is fine.
This doesnt work make sure that your fan is blowing air the right way. I have known many people when replacing the radiator to not notice something as little as being sure the fan was blowing the right way.
Also it could be the water pump and may also be head gasket.
Old May 7, 2004 | 01:06 PM
Saki's Avatar
Default Re: (92BlueCivic)
Hey guys my car yesterday just started to make this nasty noise. It sound like Metal against Metal. But i'm not losing any power. It souds like it coming from the engine, on the driver side. Anyone know what could be wrong???
Thanks in Advance,
Saki
Old May 7, 2004 | 01:43 PM
ABK's Avatar
ABK
Default Re: (Saki)
that sounds like your water pump, do you have collant leaking from that spot too? Take it to the mechanic and have him double check it, but I'm almost 100% that's what it is. You will need to get your timing belt taken off while doing that so it's a good idea to replace that too.
Old May 9, 2004 | 10:01 PM
Saki's Avatar
Default Re: (ABK)
I took the car to the mechanic, I found out what it was. The distrubutor went bad, and was making that grinding noise. I replaced it... Only Problem I still have is the car is still overheating. I did check to see if it was the Fan Switch, but the Fan switch works good. I noticed when the fan comes one when I'm idling it blows cold air. But when I tap the gas then its starts to kick out hot air, and my temp gauge starts to go back down... Anyone think of anything...
Old May 9, 2004 | 11:30 PM
FcUK It.'s Avatar
i have the same problem, bump
Old May 10, 2004 | 01:45 AM
Saki's Avatar
Default Re: (frosteg6)
Really, ever figure out what it was???
Old May 10, 2004 | 11:44 AM
FcUK It.'s Avatar
not yet
Old May 10, 2004 | 12:03 PM
Millenion LTD.'s Avatar
California,The only state
car overheating a lot does crap to the head gasket, maybe you should replace it
iani_2006
Dec 14, 2005 07:40 AM
otakueric
Apr 1, 2004 02:05 PM
EGhatched
Mar 14, 2004 04:17 PM
