RPM's going up and down
Old Nov 2, 2001 | 06:47 PM
sa21199's Avatar
Default RPM's going up and down
When i park my car and i'm about to turn it off I have noticed that the rpm's rev up a little bit (only like a couple of the dashes on the tach). I have a 97 gsr in case you are wondering. Also, my car idles at close to 2k when i first turn it on in the morning..how do i adjust this?
Old Nov 2, 2001 | 10:50 PM
WykidEH's Avatar
Default Re: RPM's going up and down (sa21199)
That's your fast idle valve. . . .it's on the bottom of your throttle-body. They're two 8mm bolts that hold the cover to it. Take them off and turn the screw clock-wise until it's tight, then turn back a half a turn. That should do it.
mecca858
Feb 25, 2015 08:20 AM
crazyhouse2011
Aug 28, 2013 11:02 PM
bpetruzzo
10
Nov 8, 2005 02:07 PM
bathanr
Jun 29, 2005 06:50 PM
