TPS question
Old May 2, 2004 | 11:08 AM
RCautoworks's Avatar
Default TPS question
Just wondering if a tps could go bad. I tried recalibrating it but it would not get close to spec, either I had it perfect at w.o.t and at close throttle it was really off or the opposite.
Old May 2, 2004 | 02:29 PM
Xsi's Avatar
Xsi
They can go bad but not often. Does the car run ok when you set it for closed throttle? I just set mine at closed throttle and don't pay any attention to WOT.
Old May 2, 2004 | 02:30 PM
Default Re: (Xsi)
So your not suppose to pay attention to wot ? The car runs fine, but every now and then the tps code will pop up.
Old May 2, 2004 | 02:38 PM
techer's Avatar
Default Re: (90blackcrx)
it can go bad. check with an analog voltmeter on the feedback wire, it should sweep evenly with an even opening and closing of the butterfly
Old May 2, 2004 | 03:02 PM
Default Re: (techer)
See it seemed fine, but the only problem was it would not get close to spec. So whats more important, wot or just at idle ?
Old May 2, 2004 | 04:04 PM
Xsi's Avatar
Xsi
I'd be more concerned about idle, my car had a lumpy idle and it took me ages to get it just right. What voltage are you setting it at? and how is you idle?
Old Jun 6, 2004 | 08:48 AM
dcb16's Avatar
Default Re: (Xsi)
im gettign same problem, except i have all correct voltages, car runs fine, but i get CEL 7,
any one?
Kid-jdm-teggy
Jan 18, 2014 07:20 AM
Throwback23
May 4, 2010 09:33 PM
salman
Sep 18, 2006 08:40 PM
mafay2
Jul 4, 2005 06:35 PM
kaj
Sep 1, 2004 04:37 PM
