Help with JDM H22 engine swap (Wire harness) for my 95 honda civic
Hi, you guys help me a lot with my last question, however there is something that I'm not completely clear: if I do the engine swap (H22 to 1995 civic EX) I need to modify My wire harness to fit the H22 computer?; Or do I need to modify the H22 wire harness to fit my stock computer?
Your help will be apreciated...... Thanks.......
I think it would go in like any B series would. If its OBD1 itll go right in. If its OBD2 then youll need a jumper.
I never done a h22 swap so i dont know, but thats my guess.
your using your civic engine harness i hope
you are going to keep your civic chassis harness so the ecu clips will be for OBD one
IF your h series ecu is obd two you need to a) get a obd one ecu (this one i would do) or get a jumper obd two to one
https://honda-tech.com/zerothread?id=650329
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigjussin »</TD></TR><TR><TD CLASS="quote">will stock p72 fuel and timing tables work on a jdm h22 motor?
yes BUT you should chip it to h series maps
