what make a Type R motor different than a GSR motor??
Old Nov 2, 2001 | 03:49 PM
lazyvietboi's Avatar
Default what make a Type R motor different than a GSR motor??
list all that u can know..
Old Nov 2, 2001 | 03:54 PM
sackdz's Avatar
Default Re: what make a Type R motor different than a GSR motor?? (lazyvietboi)
One says B18C1 on it and the other says B18C5
Too much to list, here's some:
Higher Compression
Lighter valvetrain
Different Intake Manifold
Limited Slip Differential
Shorter gear ratios
Old Nov 2, 2001 | 03:55 PM
Night Kid's Avatar
New User
b16 head w/ porting, shorter single butterfly intake manifold, higher compression pistons, stronger clutch, bigger throttle body, lsd..
Old Nov 2, 2001 | 04:14 PM
2005 TSX's Avatar
Default Let's see...
What make a Type R engine different than a GSR engine??
A measly 25 more horsepower in stock configuration. Plus some fancy components to get that horsepower. That's about it.
[Modified by 2001 Integra GSR, 5:17 PM 11/2/2001]
Old Nov 2, 2001 | 04:27 PM
Default so if i get these for a GSR would it be stronger..
GSR Motor w/:
new camshafts (maybe TODA)
cam gears (maybe TODA)
new valvetrain (maybe Skunk2's or portflow or ITR??)
LSD
Skunk 2 intake manifold w/some kind of bigger TB
port and polish
lighten flywheel
better clutch
OR
Type R motor w/:
new valvetrain. i duno if i should keep the b18c1 valvetrain or get aftermarket ones
new camshafts. i dunno bout these too. to keep it stock or get aftermarket ones.
i dunt really know if i should get Type R motor or GSR.
Old Nov 2, 2001 | 05:17 PM
Malice's Avatar
New User
Default Re: so if i get these for a GSR would it be stronger.. (lazyvietboi)
$2000 price difference...i'd go with the geeser. i was in the same dilemma 6 months ago. i got the GSR motor and put in about $1000 worth of parts(hook up prices) and i walk lightly modded R's in the 1/4mile in my sedan!. the R would eventually catch up on the freeway tho.
good luck
Old Nov 2, 2001 | 08:09 PM
Chris's Avatar
Default Re: so if i get these for a GSR would it be stronger.. (MaliceGSR)
I had a GSR (98) and let me say the difference IS NOT MEASLY.
The car is so much more SOLID, faster, agile, the list goes on.
A modded GSR is still not gonna be an R. I tried to get My GSR up to R performance...not even close.
Old Nov 2, 2001 | 08:23 PM
2005 TSX's Avatar
Default Chris
Remember though, we are talking about engines, not how solid or agile the the car is. To bring a GSR engine to Type R horsepower is pretty easy to do.
Old Nov 3, 2001 | 05:57 AM
MiraiZ's Avatar
Default Re: Chris (2001 Integra GSR)
but...to bring a GSR to a TYPE R is not
Old Nov 3, 2001 | 06:46 AM
RJL's Avatar
RJL
New User
They are plenty of of equipped GSRs that will tear on Type Rs, but not from the factory. But Ive heard that by putting an ITR or B16 tranny on a gsr, Quarter mile times are about .10-.15 behind and Type r
Old Nov 3, 2001 | 07:48 AM
Malice's Avatar
New User
Default Re: what make a Type R motor different than a GSR motor?? (Badboy01GSR)
intresting....any truth to this guys?
Old Nov 3, 2001 | 08:37 AM
Its_real&its_spectacular's Avatar
New User
Default Re: what make a Type R motor different than a GSR motor?? (MaliceGSR)
Doesn't sound right to me. You'd think that the extra 25 horses and the extra rpm would count for something too...
Old Nov 3, 2001 | 09:22 AM
Jason's Avatar
Default Re: what make a Type R motor different than a GSR motor?? (Its_real&its_spectacular)
not to mention the diet the Type R was put on...it weighs close to 100 lbs less (w/out A/C)
Old Nov 3, 2001 | 09:48 AM
Default Re: what make a Type R motor different than a GSR motor?? (typer98)
whoa
Old Nov 5, 2001 | 07:41 PM
Real_E-AT's Avatar
but wait you posted in the forced induction section....maybe you should make up your mind....
Old Nov 5, 2001 | 07:49 PM
Default Re: so if i get these for a GSR would it be stronger.. (ChopSuey)
dude.. this is my home schooling.. im trying to learn here. stop interupting me..
[Modified by lazyvietboi, 8:51 PM 11/5/2001]
Old Nov 5, 2001 | 08:13 PM
comptechgsr's Avatar
the R has more "Vtec"
lol
do a search
Old Nov 5, 2001 | 08:33 PM
Nick M's Avatar
Default Re: so if i get these for a GSR would it be stronger.. (comptechgsr)
My friends 95 GSR 4 door weighed 2657 at the track in street trim. How does that compare to the weight of a Type R? How much lighter are they?
Old Nov 5, 2001 | 08:53 PM
jmb's Avatar
jmb
read this article http://integra.vtec.net/carboy.html
2Nyce
Nov 9, 2010 11:19 AM
moto88xxx
Mar 17, 2010 08:15 PM
jjmcmana
Jul 7, 2009 07:19 PM
mistaxjimbo
Aug 10, 2004 08:02 PM
hbsi504
15
Oct 24, 2003 02:27 AM
