Swap problem - Crx b16
Old May 1, 2004 | 10:14 PM
souljad9's Avatar
Default Swap problem - Crx b16
Were in the middle of doing my friend's swap, And we've hit a snag. Everything's in, the motor cranks, but doesn't start. We're figuring it's a fuel problem, because when you spray starter fluid in the intake (not my idea), it catches, and will backfire. You can also hear a sort of gurgling noise coming from the fpr. Any Ideas?
Old May 1, 2004 | 10:20 PM
goodwinesi's Avatar
Default Re: Swap problem - Crx b16 (souljad9)
Is everything wired up? Plugged in? Is it grounded good?(crucial) Got your plug wires in the right places? Lot of things it could be man.
Old May 1, 2004 | 10:59 PM
michael O's Avatar
Default Re: Swap problem - Crx b16 (goodwinesi)
check your wiring. I just got my swap started because I wired the dizzy up wrong.
Old May 2, 2004 | 07:36 PM
C-REX 88's Avatar
Ya i would say check the grounds. I had the same problem, no fuel was getting to the fuel rail. Ilooked around and found a ground off. After i connected it it worked fine
Old May 2, 2004 | 08:01 PM
0554's Avatar
sounds kinda like the plug wires are on backwards. i donno to hard to say with such little info.
Old May 2, 2004 | 08:07 PM
michael O's Avatar
Default Re: (88crex)
my dizzy was wired 180 degrees off and the car still ran when I sprayed starter fluid in it just ran like ****. So I say double, triple, quadruple check wiring.
crxracer2006
Sep 22, 2005 11:46 AM
CHAPY
Apr 15, 2005 09:03 AM
91_civicsi
17
Jun 11, 2004 08:26 PM
90_Civic_Hatch
10
Aug 9, 2002 11:05 AM
Hayate42
Apr 10, 2002 12:56 PM
