converting to r134a, how do i put the oil in?
Old May 1, 2004 | 06:01 PM
importboi22's Avatar
Default converting to r134a, how do i put the oil in?
where do i put the ester oil in at?
Old May 1, 2004 | 06:09 PM
Default Re: converting to r134a, how do i put the oil in? (importboi22)
just found this
http://www.duracoolky.com/index.html
think im gonna try it out, but how do i put the oil in still?
Old May 1, 2004 | 06:29 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importboi22 &raquo;</TD></TR><TR><TD CLASS="quote">how do i put the oil in still?</TD></TR></TABLE>
You can't.
You have to be certified to mess with it.
Old May 1, 2004 | 07:12 PM
1991EFBeater's Avatar
I wouldn't try it my self cause its a very long ******* process cause you got to take the air conditioning compressor and empty all the r12 and then recharge the r134a and make sure your air condinter is on when recharging it and make sure it is holding pressure.
Old May 1, 2004 | 07:24 PM
wtsexton's Avatar
Default Re: converting to r134a, how do i put the oil in? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You can't.
You have to be certified to mess with it.</TD></TR></TABLE>
Not for 134a
Old May 1, 2004 | 10:44 PM
tilt's Avatar
you just run it into the ac system via the low pressure port -- same as putting in the r134a. if you buy a kit the oil should already be mixed in with the r134a cans. just read the instructions, it's pretty self explanatory. hth
think im gonna try it out, but how do i put the oil in still?</TD></TR></TABLE>
Old May 1, 2004 | 11:04 PM
Default Re: converting to r134a, how do i put the oil in? (tilt)
i think i got it i put about 4 ounces of oil in the compressor
Old May 1, 2004 | 11:11 PM
bossman032's Avatar
you can use ester.
make sure you don't contaminate the system
once u do that you fuckup your ac system!
I suggest u do it the right way get the pressure gauge, leak tester etc.. put some dye in it while u at it if it leaks you can find it with black light
riceball777
Feb 5, 2008 03:23 PM
crazyguy
Sep 27, 2007 04:38 PM
1.8
Jan 10, 2005 09:40 PM
thecoolerguy
Oct 3, 2004 02:39 PM
Kid1320
10
Apr 16, 2004 09:55 PM
