differences between civic and del sol
Old May 1, 2004 | 03:15 PM
speedbreed's Avatar
Default differences between civic and del sol
are most of the parts on a 92-95 civic interchangeable? i've been researching and there doesn't seem to be a lot of parts out for the del sol. and if parts are interchangeable, i have nothing to worry about. my other choice of a car is the 96-00 civic hatch.
Old May 1, 2004 | 03:20 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: differences between civic and del sol (speedbreed)
92-95 civics and del sols are almost identical except for a del sol is 2 seater. any suspension, engine mod from a civic will 99.9% of the time bolt up to a del sol. 94-01 integras as well. just check the mods in my H-T garage and you'll see how much stuff off of a GSR bolted right up to my del sol.
Old May 1, 2004 | 04:25 PM
asmallsol's Avatar
basicly other then body work, the only thing that is diffrent is the shift linkages and exhaust.
If your doing a swap, you need del Sol VTEC linkages, and for exhaust, well, it blows because no one makes sol exhaust.
Old May 1, 2004 | 07:15 PM
speedbreed's Avatar
Default Re: (asmallsol)
where can i get sol shift linkages and exhausts. i want to put in a b18 type r. the hatchback seems to be the better thing to do but i love how the del sol looks.
Old May 1, 2004 | 07:17 PM
diearzte2
Guest
Posts: n/a
Default Re: (speedbreed)
hmotorsonline.com will have most everything you need for a swap. Check local exhaust shops for exhaust options. Custom bent exhaust will most likely be your only choice.
Old May 1, 2004 | 07:25 PM
spirit R
Guest
Posts: n/a
Default Re: (diearzte2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diearzte2 &raquo;</TD></TR><TR><TD CLASS="quote">hmotorsonline.com will have most everything you need for a swap. Check local exhaust shops for exhaust options. Custom bent exhaust will most likely be your only choice.</TD></TR></TABLE>
or not
http://www.optauto.com/webstor...=1199
Old May 1, 2004 | 07:26 PM
spnfed's Avatar
Depends on how much money you want to spend on a exhaust, GReddy and Tanabe both make two different model's for Delsol's.
My girlfreind has the older GReddy SP on her sol, and it sounds great.
Old May 2, 2004 | 03:44 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (spnfed)
the new greddy evo exhaust is out for del sols. i personally like the skunk2.
Old May 2, 2004 | 06:47 AM
asmallsol's Avatar
Default Re: (spirit R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirit R &raquo;</TD></TR><TR><TD CLASS="quote">or not
http://www.optauto.com/webstor...=1199</TD></TR></TABLE>
Holy ****!!!! Its about ******* time. I have been emailing RSR for about 6months asking them to make exhaust for the del Sol. Hmm, I might have to buy pretty soon.
Old May 2, 2004 | 08:46 AM
speedbreed's Avatar
what do i have to do to the shift linkage? whats the difference?
Old May 2, 2004 | 08:48 AM
skip.two's Avatar
buy me one too asmallsol
Old May 2, 2004 | 09:00 AM
asmallsol's Avatar
Since the placement of the shifter is diffrent on the del sol then a civic or an integra, if you use Civic SIR linkages or integra's, then the linkage will hit the subframe. you need to buy the del Sol VTEC linkages (VTEC = dohc b16a3 del sol model, offered from 94-97) I got mine new from honda for about 130ish (cant remember the exact price, but whatever) I would also recomend that you pick up some polyurathane shifter bushings (about $15-20)
Old May 2, 2004 | 09:04 AM
Ejay Six's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol &raquo;</TD></TR><TR><TD CLASS="quote">
Holy ****!!!! Its about ******* time. I have been emailing RSR for about 6months asking them to make exhaust for the del Sol. Hmm, I might have to buy pretty soon.</TD></TR></TABLE>
Looks good
Old May 2, 2004 | 09:45 AM
spnfed's Avatar
Default Re: (Ejay Six)
Clean looking.
Old May 2, 2004 | 09:51 AM
xavior66's Avatar
HASport is also another awesome place to look for swap parts. Though they do not sell engine swaps outright, they sell just about every part (even freakin' wire harnesses!) you'll need to do a swap.
Old May 2, 2004 | 10:07 AM
deeksmooth's Avatar
the muffler looks A LOT like the OE CTR
Old May 2, 2004 | 02:00 PM
SolObsession's Avatar
Default Re: (citrEK)
What size piping does the RS*R Ex-Mag exhaust for the sol come with?
I want one but I don't see where it says the size of the piping.
Old May 2, 2004 | 02:09 PM
asmallsol's Avatar
I belive that it is 60mm.
Old May 2, 2004 | 02:16 PM
KamikazeSol's Avatar
I have the old RSR, which looks exactly like the one in the pic and it is 61mm. It is a great exhuast, not to loud and does not stand out too much.
Old May 2, 2004 | 02:22 PM
So the tip is 61mm. To be more specific, I am going turbo and currently have a 2.25" custom bent system. Is 61mm 2.5" or what would the conversion be? I see KamikazeSol has a turbo sol so it must be good?
Old May 2, 2004 | 02:42 PM
Default Re: (SolObsession)
It is 1mm shy of 2.5". It it roughly 24.5mm to an inch. Also the exhuast has not been bad for my turbo. It could use 3" for a bit more power, but as oon as I get to the dyno next week I do not think my 300 horse power goal will be effected too much by the exhuast.
Old May 2, 2004 | 02:43 PM
Thanks.
Old May 2, 2004 | 06:21 PM
asmallsol's Avatar
Default Re: (KamikazeSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KamikazeSol &raquo;</TD></TR><TR><TD CLASS="quote">It is 1mm shy of 2.5". It it roughly 24.5mm to an inch. </TD></TR></TABLE>
No it is not. Google conversions is your freind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">60 millimeters = 2.36220472 inches.</TD></TR></TABLE>
Old May 2, 2004 | 06:32 PM
B16Drag's Avatar
damn that RSR looks sweet never heard of one, but it is very tempting since it will look almost like stock... any word if its availble in 2-1/2"? or close to 65mm? I'll be turboing as well and that looks tempting!
Old May 2, 2004 | 07:22 PM
spirit R
Guest
Posts: n/a
Default Re: (B16Drag)
JDMers say 2.5 in when its really 2.38in
Ive had 6 RS-R exhausts myself and I've loved them all. Turbo did an article back in the day where they only made 1 more hp dropping the exhaust at the cat then having it on so good power too.
I would highly recommend RS-R
gennaro
Sep 7, 2017 03:34 AM
Honda Tech Editor
Newsletter Archive
Sep 12, 2014 01:47 PM
Pinoyjava
Nov 8, 2005 04:43 PM
bubbajim
29
May 12, 2003 04:47 AM
