Cylinder Head Gasket or Cylinder Head Gasket Set?
Old May 1, 2004 | 10:26 AM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
Default Cylinder Head Gasket or Cylinder Head Gasket Set?
There is oil leaking out of the botton of the valve cover on my JDM B16a which is on a 93 EG Civic Coupe. And I was looking at http://autopartsauthority.com and I nocited that they have two parts for sale a Cylinder Head Gasket and a Cylinder Head Gasket Set the price between the two is $57 for the Head Gasket and $160 for the Head Gasket Set. Which do I need? Do I get the one for a 94 Del Sol VTEC or 2000 Civic Si?
Old May 1, 2004 | 10:31 AM
mario82686's Avatar
Or maybe need one of these http://www2.autopartsauthority...+Seal
Old May 1, 2004 | 10:48 AM
mario82686's Avatar
Does anyone know?
Old May 1, 2004 | 10:50 AM
Nerologic's Avatar
u need a valvecover gasket, not head gasket
Old May 1, 2004 | 10:51 AM
Nerologic's Avatar
ohh and either gasket will work, but get the 00SI one its more common
Old May 1, 2004 | 11:18 AM
mario82686's Avatar
Where can you get a valvecover gasket?
Old May 1, 2004 | 11:20 AM
mario82686's Avatar
I want the cheapest way to fix this.
Old May 1, 2004 | 11:44 AM
mario82686's Avatar
Do I need a valve cover gasket, cylinder head head, or cylinder head gasket set?
Old May 1, 2004 | 11:53 AM
EKRacer's Avatar
Default Re: (mario82686)
If it's just leaking at the bottom of the valve cover then all you is a valve cover gasket. If you don't have the money for a Honda one you can get it at any auto parts store.
Usually they have a gasket set for this too, but those usually come with the spark plug tube seals I think, so it's up to you.
Old May 1, 2004 | 03:52 PM
civicsitek GanGsTa's Avatar
Default Re: (EKRacer)
just go to Napa, tell them what car you have and that you need a valve cover gasket. Take your valve cover off, clean the mating surface on the head and on the valve cover, put the new gasket on, and tighten everything back down.
Davidkak
Apr 3, 2010 12:13 AM
Chuethou_b18c5
May 1, 2006 11:51 PM
Powered By Garrett
Mar 7, 2005 06:50 PM
