rods to crank
Old Apr 30, 2004 | 08:45 PM
love2xlr8integra's Avatar
Default rods to crank
do the rods need to be sized to the crank. I have Eagle Rods and oem crank.
Old May 1, 2004 | 12:19 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: rods to crank (love2xlr8integra)
No, as long as the rods are for your car, the only thing that has to be matched up are the bearings. Was the crank cut/machined in any way?
Old May 1, 2004 | 07:51 PM
the prob i am having is i bring the rods to 28 ft. lb and the crank wont move. i got new berings thinking that was the prob and nope still will not move. take the rods off and it spins free as can be.
Old May 2, 2004 | 08:05 AM
bump before work
Old May 2, 2004 | 11:42 AM
Ti3d in's Avatar
Default Re: (love2xlr8integra)
You gotta measure the rod bearing clearances. It might be too tight, which means you'll have to get another bearing. All in the process of building an engine
Old May 2, 2004 | 02:38 PM
Big Teggie's Avatar
Are you using OEM bearings?
Do you have a Helms manual?
Old May 2, 2004 | 05:35 PM
AzG35's Avatar
You have to use the appropriate rod to the same crank. For example, if using a LS crank, you need LS Rods. GSR and ITR have the same rod end sizes, so you can interchange GSR and ITR rods on either GSR or ITR cranks. B20 and LS are the same as well.
Old May 2, 2004 | 07:03 PM
"You have to use the appropriate rod to the same crank. For example, if using a LS crank, you need LS Rods. GSR and ITR have the same rod end sizes, so you can interchange GSR and ITR rods on either GSR or ITR cranks. B20 and LS are the same as well."
no i have a ls crank and ls egale rods
Old May 2, 2004 | 08:00 PM
shamoo's Avatar
You didn't answer my question before. Was the crank cut/machined in any way? Many times, when the crank is out, it is cut/micropolished and whatnot. Quite common. If it was, you can't just pop in OEM or whatever bearings in there.
Do what this guy said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">You gotta measure the rod bearing clearances. It might be too tight, which means you'll have to get another bearing. All in the process of building an engine</TD></TR></TABLE>
Also remember, Honda DOES NOT make oversized bearings. So if you had your crank cut/machined, you CANNOT use Honda bearings. In my case, I used Clevite bearings. They had the correct size I needed.
Thundercat
Mar 28, 2008 10:52 PM
r1de4life
Mar 26, 2008 02:57 PM
ItsSlow
May 30, 2006 05:54 PM
xparkesx
18
Mar 8, 2005 09:03 PM
mattjohnston
Dec 9, 2003 03:35 PM
