What axles do I use!!! B18c with hydro into crx????? Help
Ok, I got a set of 90-91 teg axles/ int shaft, and a set of 95 gsr axles/ int shaft. I also have 91 j1 tranny seals, and 95 gsr seals. I should be able to mix and match parts, so what do I do?
It seriously seems like I am the only one trying to do this setup, its so hard...
Some people have a hydro tranny on there b16, and others have a cable on there b18c.... its frustrating.
Oh well, please help. Thanks so much for your replies in advance!! Ryan
So they are the same length as the 90-91's? I just need to remove the dust cap, correct? Ryan
I had always heard that hydraulic transmissions can use the same axles/intermediate shafts as cable transmissions. You just need the cable transmission axle seals.
OK, so should I use my 90-91 teg axles/ int shafts? Im confused. Thats what I Originally thought, but people are telling me to use the 95 axles and shafts. What gives? Thanks, Ryan
Edit: Raxles told me 95 axles would be too long. They told me 89 outers/shaft, and 95 inners and int shaft. Ryan
i just installed mine, i used a 91 inter shaft and axles. with a 96 ls tranny. i changed the driver side tranny seal. seem to work good but i didnt drive the car yet, something seems to be wrong with my clutch. its not disingauging.
btw: i had to find out the hard way, if your clutch setup is for a cable tranny. then you need to change out your clutch disk to a hydro setup. you can still keep your pressure plate, just change the disk.
ryan PM me if you need any more help
-mark
-mark
Yeah, my gsr act disk is comming it the mail!! What driver side tranny seal was it? Thanks, Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">Yeah, my gsr act disk is comming it the mail!! What driver side tranny seal was it? Thanks, Ryan</TD></TR></TABLE>
the seal you have to change on your tranny, its where your intermediate shaft goes into the tranny. that seal. thats it.
turbox
Dec 3, 2004 04:55 PM
