02 s2k Bogging down hard (resembles bad Disty)
Just as the title says, it bogs very hard when you go any more than 1/5 throttle, it even idles as if it is misfiring, poor timing or improper fuel.
Open to ideas and suggestions.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra »</TD></TR><TR><TD CLASS="quote">Just as the title says, it bogs very hard when you go any more than 1/5 throttle, it even idles as if it is misfiring, poor timing or improper fuel.
Thanks</TD></TR></TABLE>
I think I am having a similar issue. Like 4-5k rpm in 2nd it bogs for a second like im misfiring. Or something. Weird.
those that are having bogging issues that are bad enough to be called misfires, are you really sure they are that bad? I mean, are you saying misfire as in the engine isn't running on all four cylinders? Swing by your dealer and have them check for any codes that may have come and gone. The MAP sensor issue is upon moving from a standstill or stuck in traffic where you are loading the engine from neutral and varying the throttle.
Yeah, unfortunately, i am sure this is sometype of a misfire. I aquired the pdf of the helms for the s2k yesterday eve and am now goinbg to check a few things. I will start with replacing my plugs and tapping on the map sensor.
If that does not work I suppose off the the aftermarket parts and back to the dealer
I need this fixed, just payed all that money for the car and now it runs like junk all the sudden
Thanks for the replies!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra »</TD></TR><TR><TD CLASS="quote">Yeah, unfortunately, i am sure this is sometype of a misfire. I aquired the pdf of the helms for the s2k yesterday eve and am now goinbg to check a few things. I will start with replacing my plugs and tapping on the map sensor.
let's us know what results from the trip to the dealer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra »</TD></TR><TR><TD CLASS="quote">As it all turns out, there were two burnt injectors. And they charged me 169.00 to replace the plugs I just put in 4 days before.
good thing you had it replaced as soon as you did. Otherwise, it could've taken out the engine.
HAh, that and found out it has been in a major wreck, I go to pick it up today, they are going to show me how they know
I hope it all gets fixed, I over paid for the car and am kinda miserable right now.
Well, there is no documentation of a wreck, clean carfax and all. It has been rewelded according to honda and the support under the plastic grommits were covered with "bondo dust" according to them. The paint has some lil bits of dirt in it, but nothing horrific, it can be wet sanded and buffed out, it just sucks that I payed what i did for a car that has had previous damage. I bought the car from texas and had it shipped here, so I really did not get to see it before it was payed for.
I guess thats the breaks. It does run great now though.
I would definitely do something about this.. Good luck.
