riding on bumpstops
Old Apr 30, 2004 | 02:32 PM
deviant1's Avatar
Default riding on bumpstops
my car is lowered on ground control coilover and illuminas. i have 16" rims and there is no fender gap on all four corners. my rears are not resting on the bumpstops but my front is. anyone know how to get the front of the car off the bumpstops and still have no fender gap? and why would my rear not be resting on the bumpstops like the front?
Old Apr 30, 2004 | 02:39 PM
_BEN_'s Avatar
Default Re: riding on bumpstops (deviant1)
cut the bump stops.
When I nstalled tein s-tech springs on my '92 si The instruction sheet said I had to cut 1.4" off the fronts and .8" off the rears.
Old Apr 30, 2004 | 06:28 PM
deviant1's Avatar
Default Re: riding on bumpstops (_BEN_)
they are cut. as of now they are cut in half if i remember correctly. its been a while. some people suggested i cut them so they are 1 inch long. would that help?
Old Apr 30, 2004 | 06:34 PM
Mohudsolo's Avatar
Ground Control has some front shock mounts that offset the top of the shock upwards. I forget how far it moves the shock, but it should get you some travel back.
Old Apr 30, 2004 | 06:51 PM
C4wrx's Avatar
get bigger wheels
Old May 1, 2004 | 01:56 PM
deviant1's Avatar
Default Re: riding on bumpstops (h22eg)
my car rides like absolute crap now. i finally got a chance to hit the freeway. OMG. dips make the car go crazy. im think about just throwing on some h&r race springs on my illuminas instead now.
Old May 1, 2004 | 02:27 PM
7thGear's Avatar
there is such as a thing as being TOO LOW you know...
read this... if you have time
http://forums.vwvortex.com/zerothread?id=621342
Old May 1, 2004 | 04:08 PM
deviant1's Avatar
Default Re: riding on bumpstops (7thGear)
i dont think im too low. im only low enough to eliminate the fender/wheel gap. thats not too bad. im not even tucking tire.
Old May 1, 2004 | 04:19 PM
7thGear's Avatar
if your A arm is higher than parallel your too low ( for handling anyway)
Old May 1, 2004 | 05:12 PM
C4wrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think im too low. im only low enough to eliminate the fender/wheel gap. thats not too bad. im not even tucking tire.</TD></TR></TABLE>
what size wheels do you have?
Old May 1, 2004 | 05:23 PM
deviant1's Avatar
16 inch 205 45 16
Old May 1, 2004 | 09:43 PM
Sliced Beard's Avatar
you should cut your bumpstop roughly in half
you can also get some yop hats that give you a bit more suspension travel to make your shocks more effective
lawlsss
Jan 17, 2009 01:34 AM
2000dollarzcbs
Oct 12, 2006 09:37 PM
TurboLaxx
Suspension & Brakes
Jan 2, 2006 08:21 PM
AlphaQup
Suspension & Brakes
Sep 11, 2005 01:20 PM
ccjb100
12
Nov 19, 2002 05:53 AM
