tie rod install question/concern
Old Apr 30, 2004 | 06:32 AM
crxgator's Avatar
Default tie rod install question/concern
well yestarday i replaced both outter tie rods. they had the original ones on it from 1991...which were shot to ****.
on the driver side i counted 18 turns on removal and 18 turns for install...for the passenger side i only counted 16 on removal and 16 on install...now my steering wheel is a smidgin to the the right when im going straight...will an alignment fix this? or do i need to run the tie rod less/more on which side... any help would be appreciated...
Old Apr 30, 2004 | 06:51 AM
spaceman's Avatar
Default Re: tie rod install question/concern (crxgator)
those tie rods are they the parts that mount from the front subframe to the front lower control arms?
Old Apr 30, 2004 | 07:11 AM
mmuller's Avatar
Mad Scientist
yeah, you need an alignment, dont try to set the toe yourself....you'll end up messing it up even more
streetsold6teeny8
Jul 4, 2008 11:33 AM
drumminforev
Apr 10, 2006 01:42 PM
Boosted Chemist
Jun 14, 2004 03:19 AM
crxgator
16
Apr 30, 2004 06:14 PM
suspendedHatch
Mar 28, 2004 11:37 AM
