How do you know if your motor is in good condition?
Old Apr 30, 2004 | 06:00 AM
tweekerz's Avatar
Default How do you know if your motor is in good condition?
What kind of tests can I do to verify my motor is healthy to be modified? What should I be looking for?
Thanks!
Old Apr 30, 2004 | 06:04 AM
greaseball's Avatar
Default Re: How do you know if your motor is in good condition? (GoodTimes)
compression test would be a good idea.
Old Apr 30, 2004 | 06:08 AM
tweekerz's Avatar
Default Re: How do you know if your motor is in good condition? (greaseball)
What kind of resulsts should I be expecting from that? I have a 01 GSR with 49K.
Old Apr 30, 2004 | 06:10 AM
xSCTYGx's Avatar
Compression test and leak down test...
The compression in each cylinder should be within I believe 6% of each other.
Old Apr 30, 2004 | 06:11 AM
tweekerz's Avatar
Default Re: How do you know if your motor is in good condition? (2Gen91Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Gen91Teg &raquo;</TD></TR><TR><TD CLASS="quote">Compression test and leak down test...
The compression in each cylinder should be within I believe 6% of each other.</TD></TR></TABLE>
And if its not than what next??
Old Apr 30, 2004 | 06:12 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Gen91Teg &raquo;</TD></TR><TR><TD CLASS="quote">leak down test...
How does that work? What kind of results can I expect form that test?
Old Apr 30, 2004 | 06:14 AM
grlstockb18c1's Avatar
damn your cars still a baby LOL. Mine on the other hand ....95 GSR 174k**sighs**
Old Apr 30, 2004 | 06:15 AM
IntEGNYC's Avatar
Default Re: How do you know if your motor is in good condition? (Grlsb18c12slow)
uhhhh ok...
fuel economy is another good measure to use.
Old Apr 30, 2004 | 06:17 AM
tweekerz's Avatar
Default Re: How do you know if your motor is in good condition? (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">uhhhh ok...
fuel economy is another good measure to use.</TD></TR></TABLE>
Yeah I get about 270-280 miles when the gas light comes on... probably about 24mpg.
Old Apr 30, 2004 | 06:19 AM
tweekerz's Avatar
I am just worried that I wont be making enough power when I throw some cams, etc on my motor! Want to know beforehand that my motor is in perfectly good health before I make an investement out of it!
Old Apr 30, 2004 | 06:20 AM
greaseball's Avatar
180-210 or around there is good compression test numbers. i have a 99 gs-r and am around 190-200 on all cylinders.
Old Apr 30, 2004 | 06:21 AM
Good idea...if not you'll end up like me!
oh yeah inTEGNYC: I meant the year and the miles
Old Apr 30, 2004 | 06:23 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greaseball &raquo;</TD></TR><TR><TD CLASS="quote">180-210 or around there is good compression test numbers. i have a 99 gs-r and am around 190-200 on all cylinders.</TD></TR></TABLE>
Worst case scenario my compression tests does not come out the way I want them to. What is the next option?
Old Apr 30, 2004 | 06:32 AM
Heylookits shawn's Avatar
just do the compression test and find out...most likely your motor is in good condition
Old Apr 30, 2004 | 06:41 AM
tweekerz's Avatar
Default Re: How do you know if your motor is in good condition? (Heylookits shawn)
I was also thinking about dynoing my car. I only have a CAI and skunk 2 exhaust on my teg. How much whp should my car be making?
Old Apr 30, 2004 | 09:16 AM
yakiroba's Avatar
Should be around 210....but only if you have a bunch of stickers
Old Apr 30, 2004 | 09:28 AM
PLRacer's Avatar
Default Re: How do you know if your motor is in good condition? (VTEC is not a crime!)
just start by doing a compression test. if u get good numbers than chances are there is nothing wrong and ur motor is healthy.
Old Apr 30, 2004 | 09:43 AM
bloobin's Avatar
Default Re: How do you know if your motor is in good condition? (PLRacer)
forget about dyno-ing it right now; if you want to know the health of your motor; do what the above mention posts suggest; Compression test & Leakdown test; This will identify if you have any problems or not. Also inspect around the valvecover and head gasket area to see if you have any oil seapage.. also check around your oilpan to see if you have any leaks.
If you want to get a good base line of your motor; you prob want to check if you need to replace: cap/rotor, spark plugs, air filter, and fuel filter. aka.. basic maintance.
good luck; but by gauging from the miles on your car.. your motor is probably a cherry.
berettagtz117
Mar 6, 2007 04:09 PM
dbiker207
Nov 26, 2006 07:10 AM
Got_soy
28
Aug 8, 2005 12:49 PM
geminis2k
Oct 6, 2003 03:47 PM
gsr~hatch
Apr 17, 2003 03:19 PM
