idle probelm after swap????
Old Apr 30, 2004 | 05:20 AM
sodacan33's Avatar
Default idle probelm after swap????
I just finished my swap an its throwin code 7 ta -throttle angle but i tps is new an its in right. but i can not adjust the cable anymore. but if i push the pulley on the tb with some force in moves back a slight bit- so can my spring be to tight? please help if you can thanks
Old Apr 30, 2004 | 05:29 AM
1's Avatar
Default Re: idle probelm after swap???? (sodacan33)
So you are just going to ignore the CEL?
Old Apr 30, 2004 | 05:40 AM
Fobtions's Avatar
Default Re: idle probelm after swap???? (1)
having a tight throttle cable wont throw a CEL. you have to calibrate the tps if it has been tampered with.
Old Apr 30, 2004 | 05:43 AM
spaceman's Avatar
did you try reseting the ecu?..theres an idle screw under the throttle rotor that you can try to adjust..good luck
cdmef
Jul 3, 2011 06:03 AM
95civic16
Jul 20, 2008 05:44 PM
1ludeEK
Apr 10, 2005 05:39 PM
ccivic
16
Jan 4, 2005 12:01 PM
DevinW
Jun 6, 2002 02:21 PM
