Skunk 2 High Compression Valves; Worth It?
Old Apr 29, 2004 | 12:41 PM
9T6EJ8's Avatar
Default Skunk 2 High Compression Valves; Worth It?
I am looking into buying a set of valves for my B16 because the timing belt broke and bent a few valves. I am considering the skunk 2 high compression valves to go with my skunk stage 2 cams but dont know if they are worth it and what kind of gains i get. plus i do not know the driveability with those valves in. so if anyone has those or something similar or has some suggestions, any would help thanks!!!
Old Apr 29, 2004 | 02:58 PM
VtecDeMoN's Avatar
Default Re: Skunk 2 High Compression Valves; Worth It? (9T6EJ8)
The gain in compression with those is miniscule. Those would be for someone building a high compression engine who is trying to bump the compression in every aspect possible. Not worth it IMO for your setup.
Brian
Old Apr 29, 2004 | 03:38 PM
skunk2gsr's Avatar
i have the high compression valves and the drivability is just like stock. i'm using the stage ones with a mugen head gasket and they work great. i don't know if there is a power difference haven't had my car dynoed
Old May 7, 2004 | 11:40 AM
ALLMOTORJ's Avatar
Default Re: Skunk 2 High Compression Valves; Worth It? (skunk2gsr)
About how much more compression would you gain if say you started with 10.6:1.? Are there other manufacturers that make higher compression valves than skunk2's?
Old May 7, 2004 | 03:34 PM
dfoxengr's Avatar
its like a 2 point gain. not worth it at all.
Old May 7, 2004 | 03:37 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Skunk 2 High Compression Valves; Worth It? (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">its like a 2 point gain. not worth it at all.</TD></TR></TABLE>
just go with the lighter dished valves and make up the compression somewhere else...&gt;IMO&lt;
Old May 9, 2004 | 10:19 PM
Andy4dtw's Avatar
From what I hear, Skunk2 valves become warped after while. Why don't you go to one of the sponsors and pick up some SuperTech or REV valves? I hear nothing but good things from those two companys. Besides they are probably cheaper than Skunk2 anyway.
castanagajt
16
Oct 5, 2009 04:39 PM
importfan2
19
Oct 21, 2008 06:18 PM
Eg2Project
Sep 24, 2006 11:48 PM
mr. wu
Jun 28, 2003 12:57 AM
h46it
Jun 2, 2002 09:36 PM
