OBD2b CEL's
Old Apr 29, 2004 | 09:52 AM
CRITTERMATT's Avatar
Default OBD2b CEL's
Are the CEl's from http://www.c-speedracing listed for 96-98 civics the same as the codes for the 99-2000 models. I have tried searching and have been unsuccessful. I have CEL from my engine swap. It is a B16a2 in a 99EX with a 2000 si ecu and wiring harness. ANy help would be appreciated.
Old Apr 29, 2004 | 10:03 AM
Katman's Avatar
Default Re: OBD2b CEL's (CRITTERMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT &raquo;</TD></TR><TR><TD CLASS="quote">Are the CEl's from http://www.c-speedracing listed for 96-98 civics the same as the codes for the 99-2000 models. I have tried searching and have been unsuccessful. I have CEL from my engine swap. It is a B16a2 in a 99EX with a 2000 si ecu and wiring harness. ANy help would be appreciated.</TD></TR></TABLE>
yup yup...
OBD2a & b share the same MIL codes & P codes.
Infact, roughly all 88-01 civic & integra's share the same MIL codes.
Old Apr 29, 2004 | 10:23 AM
Default Re: OBD2b CEL's (Katman)
Thank you. I thought they were but i was told by someone else they weren't. Do you have to use a scanner to get the Pcodes.
Old Apr 30, 2004 | 05:39 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to use a scanner to get the Pcodes.</TD></TR></TABLE>
Yes you do sir.
Old Apr 30, 2004 | 07:26 AM
Default Re: OBD2b CEL's (EE_Chris)
Thanks for your help. I did it yesterday and found out it was my primary O2 sensor. I had it scanned and then I jumped the harness and checked the code. They were both the same so I guess I need an O2 sensor.
alohadaily
Mar 9, 2015 12:30 PM
i2ishift
Jun 9, 2009 05:41 AM
igt7
28
Aug 17, 2008 04:41 PM
92eg6
12
Jun 3, 2004 11:52 AM
