ECUs
Old Nov 1, 2001 | 08:35 PM
CivicT's Avatar
Default ECUs
I have a 93 Si with a 95GSR motor. The motor has PR3 pistons for 11.5 compression. Other than that the motor is stock with I/H/E. I am thinking about getting a chipped ECU. What type of ECUs will work with my motor? Which programs are best? JUN,Skunk2, etc.? How much HP gain is to be expected from this upgrade.
Thanks,
CivicT
Old Nov 2, 2001 | 05:33 AM
eg6ajk's Avatar
Default Re: ECUs (CivicT)
hard to asy which program will make the power, there so many different variations, Spoon is a good start, also are you using the stock intake manifold or SKunk2 manifold....
if stock only one choice P72 sotck or chipped, with skunk2, you can use p28, p08, p70, p91 all with a chip or p30, p61, all in stock form or chipped again
if interested i sell ecus and chips..check my website
Old Nov 2, 2001 | 08:13 AM
rainforest's Avatar
Default Re: ECUs (eg6ajk)
you want something with more fuel lower vtec more redline. then do your timing manually.
Old Nov 2, 2001 | 09:03 AM
Screamer's Avatar
Check the "ecu programming?" thread which is also in the Tech section, and make your choice.
JDMB18CEJ1
Mar 5, 2008 12:45 PM
db8gsr_teg
Mar 22, 2006 10:50 AM
ablack934doorcivic
15
Jul 29, 2004 10:10 PM
xplanetearth420x
Apr 22, 2004 09:28 PM
SiR HatchAlot
Oct 1, 2003 12:26 AM
