does anyone have a TUNED hondata map for a b18b w/ drag turbo setup?
Old Apr 29, 2004 | 08:12 AM
turbolsintegra26's Avatar
Default does anyone have a TUNED hondata map for a b18b w/ drag turbo setup?
Hey I have hondata s200B and I've been tuning off the base map hondata has, I'm looking for some one out there that has a similar set up and a really good tune I can use as a base map. I just need someone to email me the .bin file, so I can import it into my Romeditor, I have the wideband and the romulator, but I haven't been able to get on a dyno yet, and I want to take this tuned map and fine tune off of it on the street and then on the dyno. I'm hoping for a map that is tuned for 10-11 psi
here is my setup
first off I'm @ 4500 ft elevation
running open loop all the time
95 integra B18B stock internals
Drag 3 kit W/ drag i/c & standard I/C pipping
Turbonetics T3/T04E .63 a/r & 54 trim
Tial Waste gate
DSM 450 injectors (w/ resistor box)
BBK fuel pump running
fuel pressure @ 50 psi
High flow cat and Thermal Research 3" exhaust
If there are any other important things I have forgot let me know. I know there has to be some one out there with a similar set up and a well tuned hondata map.
Also if you can include your power results on the map and any weak areas that may need the first bit of attention.
Thanks Justin
Old Apr 29, 2004 | 09:29 PM
Default Re: does anyone have a TUNED hondata map for a b18b w/ drag turbo setup? (Turbointegra22)
HELP, I know some one out there can help me....
Old Apr 30, 2004 | 07:20 PM
Bump
irocdaparty85
Jul 25, 2005 09:23 AM
turbolsintegra26
Apr 30, 2004 08:10 PM
CivicGSR225
Feb 3, 2004 06:06 PM
PrecisionH23a
Sep 3, 2002 09:11 PM
