Who has a tuned hondata map for a stock B18b with t3/t04e 54 trim 63 a/r
Hey I have hondata s200B and I've been tuning off the base map hondata has, I'm looking for some one out there that has a similar set up and a really good tune I can use as a base map. I just need someone to email me the .bin file, so I can import it into my Romeditor, I have the wideband and the romulator, but I haven't been able to get on a dyno yet, and I want to take this tuned map and fine tune off of it on the street and then on the dyno. I'm hoping for a map that is tuned for 10-11 psi
here is my setup
first off I'm @ 4500 ft elevation
running open loop all the time
95 integra B18B stock internals
Drag 3 kit W/ drag i/c & standard I/C pipping
Turbonetics T3/T04E .63 a/r & 54 trim
Tial Waste gate
DSM 450 injectors (w/ resistor box)
BBK fuel pump running
fuel pressure @ 50 psi
High flow cat and Thermal Research 3" exhaust
If there are any other important things I have forgot let me know. I know there has to be some one out there with a similar set up and a well tuned hondata map.
Also if you can include your power results on the map and any weak areas that may need the first bit of attention.
Thanks Justin
here is my setup
Tial Waste gate
Thanks Justin
Re: Who has a tuned hondata map for a stock B18b with t3/t04e 54 trim 63 a/r (Turbointegra22)
Find a tuner or get a wideband and tune it yourself.
People seem to not understand that EVERY car is different and basemaps arer just that BASEMAPS. Meaning to get you to a tuner to be tuned. That is the purpose of eng. mgmt. If it were as simple as passing around a program from car to car there wouldnt be a need for Hondata, Uberdata, Crome or anything. We would just all be running around on burned chips because all our setups were close to each other.
Not trying to be an ***, but get yourself the equipment to tune it yourself or just get a tuner.
Re: Who has a tuned hondata map for a stock B18b with t3/t04e 54 trim 63 a/r (Silverbeast)
ya is your AFR already tuned with your wideband? i can understand if you didnt even have a wideband yet and wanted to just run safely, but if you do then all there is now is to extract that last bit of power which only a dyno will do.
i'd kill to have the nice $ parts you have. suck it up and dyno already
turbolsintegra26
04-30-2004 07:20 PM
