Clutch replacement -- Flywheel resufacing needed?
Old Apr 28, 2004 | 04:18 PM
Atheist's Avatar
Default Clutch replacement -- Flywheel resufacing needed?
Someone just told me that when you replace a clutch you should resurface the flywheel. Is this true? If so, why? I have changed a clutch before but did not resurface the fly, but I dont know the end result as I sold it a few weeks later. Seemed fine for that time, however.
Old Apr 28, 2004 | 04:24 PM
Atheist's Avatar
Never mind, just confirmed that you should and why. Thanks though!
Old Apr 29, 2004 | 09:57 AM
tgreaves's Avatar
Default Re: Clutch replacement -- Flywheel resufacing needed? (Atheist)
Glad I could help out..
Old Feb 3, 2005 | 12:19 PM
BigC-ivic's Avatar
Default Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">Never mind, just confirmed that you should and why. Thanks though!</TD></TR></TABLE>
please share, I'm searching for this info
and by resurface... you mean like an cheap $50 job
Old Feb 3, 2005 | 12:41 PM
Atheist's Avatar
wow I was a NOOB when I made that thread! You resurface the flywheel so that you have 2 perfectly flat surfaces so that you dont cause uneven wear in the clutch. If you don't the clutch will chatter at best, slip a ton at worst.
rich7777
Jan 3, 2011 03:21 PM
aZnjCC
Mar 6, 2006 07:09 AM
cdnB18C1
Feb 25, 2006 11:08 AM
Heinz57
12
May 26, 2003 04:34 AM
Keane Rated R
Jan 13, 2002 11:45 AM
