BUSHINGS FOR MY LOWER CONTROL ARMS???
hey i have a 89 crx si and i just took my lower control arm off in the back and it looks like it might need some help... some bushings or somthing to replace the whole part where the screws go into.. just looks all tore up.... anyone know where i can find some new bushings or somthing??
Energy Suspension makes the best ones you could get them at summit. Id suggest doing all of them while your at it. Plus it a very good suspension mod
if u are looking for some rear LCA
I went with soem aluminum srr in my project
and well have the rear stock ones I had installed the ES bushings into
it is a pain I can tell u that
and well if u interested let me know
I got them from my 89 civic lying aroung somewhere in the back
PM me
PM me
You can either replace the arms or bushings with stock rubber or get a set of Energy Suspension or Prothane bushings and put them in-very simple upgrade for the lower control arms. If you need the BIG ones for the trailing arms that is a different story. The general choices are to find a pair of stock units or go with either the ES or Prothane replacements. The Trailing Arms should be removed from the car to do them tho.
Where to buy the parts-Summit or Ultra Performance is where I shop for these items. Stock-online or your local dealer. My dealer matches online pricing.
The LCA's or more properly titled trailing arms should be fine, just check for any cracks above and around the main bushing. use a standard bush, i cant stress this strongly enough, see my other post in the other current thread about passive rear steering. The only problem is changing the bush, you need a press to do it!
Rob.
11
Jul 8, 2012 07:13 PM
Rob.
Suspension & Brakes
Jul 8, 2012 10:29 AM
IrishRex
Aug 21, 2003 07:35 AM
RacerBoy
12
Apr 3, 2003 08:06 AM
rsx03
Oct 27, 2002 04:20 AM
