distributor seized, timing belt jumped, freaking out...
Old Apr 28, 2004 | 11:02 AM
steronz's Avatar
Default distributor seized, timing belt jumped, freaking out...
Last week my distributor froze up. Here's a fun picture of the fried bushing I took out of it:
I installed my new one today and it wouldn't start. I guess I was in denial about the potential consequences of a seized dizzy, so I hadn't bothered to check anything. I took off my starter and checked out all the teeth, and everything looked in order. Then I took off the valve cover and timing belt cover:
I'm guessing the two "UP" arrows shouldn't be 90 degrees off like that. So... I'm kind freaking out right now... did I bend valves? I've never had to crack open an engine before. Would somebody mind walking me through exactly what I should do now? I'ma go drink some beer...
Old Apr 28, 2004 | 11:04 AM
BAZ's Avatar
BAZ
Default Re: distributor seized, timing belt jumped, freaking out... (steronz)
Is the crank at TDC?
Old Apr 28, 2004 | 11:06 AM
spaceman's Avatar
find out the correct way to set the timing and dont freak out dood
Old Apr 28, 2004 | 11:11 AM
joesefcivic's Avatar
i sure hope the crank is not at top dead center. that would suck ***.
hondahans's Avatar
I did a swap for a friend and were getting no spark, so we switched dizzys and the same thing happened. His froze on my motor (lucky bastard he is) and the cams jumped almost identical to yours. Even being an interference motor, I had no collision problems. I would hope you are in the same boat. Just take off your timing belt and redo your timing. Make sure that you are at TDC, then match the cams, put it all back together. Don't get worked up, I think you'll be ok.
Old Apr 28, 2004 | 11:13 AM
mr. carpenter's Avatar
you might have bent valves depending on how hard you were revving it. if so just replace the valves or the head. reset timing top and bottom, put in new distributor and try to start it. if it starts and runs fine you've done no damage. if you hve to give it alot of gas to keep it running then you're losing compression and have bent some or all of the valves
Old Apr 28, 2004 | 11:17 AM
PhatOptimo's Avatar
reset the timing. fix/replace your distro first.
read the manual
http://www.hondaclubcr.com/doc...c.pdf
Old Apr 28, 2004 | 11:27 AM
rsbad454's Avatar
Default Re: distributor seized, timing belt jumped, freaking out... (PhatOptimo)
id say take your intake cam out so it will be easier to line up....less chance of it hitting piston. when crank and exhaust are at TDC then drop intake cam back in and torque to spec. Do a compression check once everything is lined up.
Old Apr 28, 2004 | 11:55 AM
kur0ryu's Avatar
Default Re: distributor seized, timing belt jumped, freaking out... (rsbad454)
I had mine set like that when I got my engine, I should have checked it before hand stupidly. I pulled off the head thinking I bent them, but they were fine, so you probably are ok.
Old Apr 28, 2004 | 12:29 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: distributor seized, timing belt jumped, freaking out... (kur0ryu)
lol... :raises hand:
ive done this, timming jumped.. and i was soon shoping for new valves.
was that a jap distributor, or was it a back east?
Old Apr 28, 2004 | 12:58 PM
steronz's Avatar
Thanks PhatOptimo, the b16 shop man is exactly what I needed. I reset everything to how it should be and fired it up. Now it rattles like a ****. Can I assume that's a bent valve whacking into the cylinder head?
Built b16a - the distributor that seized came from japan with my engine. I'm guessing mine didn't fall into the "30-40 thousand mile average."
Old Apr 28, 2004 | 01:36 PM
rsbad454's Avatar
Default Re: (steronz)
give it a compression check like i suggested.........
Old Apr 28, 2004 | 01:44 PM
steronz's Avatar
Default Re: (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">give it a compression check like i suggested......... </TD></TR></TABLE>
heh, I didn't want to admit it but... how do I go about doing that?
edit: nevermind, used search. gonna go track down a tester.
Old Apr 28, 2004 | 04:51 PM
ceLtic's Avatar
N/A wh0re!
**** that sucks. wish you goodluck and hope to keep going!
Old Apr 28, 2004 | 05:35 PM
steronz's Avatar
Default Re: (ceLtic)
Results of my compression test:
195 195 195 180
I thought it'd be a lot lower... perhaps I just bent a valve a little bit? What do the experts think?
Old Apr 28, 2004 | 07:01 PM
paybac4223's Avatar
you are probably ok... as long as you dont have more than a 20-25 psi diffrence... 180 doesnt sound too bad for a 12 year old motor... others can chime in if im wrong....
Old Apr 29, 2004 | 01:17 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steronz &raquo;</TD></TR><TR><TD CLASS="quote">Built b16a - the distributor that seized came from japan with my engine. I'm guessing mine didn't fall into the "30-40 thousand mile average." </TD></TR></TABLE>
still could of had 30-40K, but who knows if that 10 yr old engine sat in someone backyard, for 10 years of weather and rain?
then.. that nice and wet boat ride.. like i said.. i raised my hand.. lol
and the engine #'s look ok.. but the 1st thing i though, valves.. happened to me too many times. lol.. good luck.
Old May 2, 2004 | 08:06 AM
VtecKiDD's Avatar
Default Re: (Built B16A)
thoe comp # are fine, u gotta find where the rattling is coming from!
pinoyboy204
Mar 2, 2010 06:21 AM
hassan21
Oct 9, 2007 06:35 AM
vxnine
17
Jul 26, 2005 01:56 PM
vxnine
Jul 26, 2005 09:44 AM
DrewDown
Nov 18, 2004 07:05 PM
