i want to kno whats the best pistons to use on a b18a block if i want to do lsvtec
Old Apr 28, 2004 | 09:35 AM
jspechatch04's Avatar
Default i want to kno whats the best pistons to use on a b18a block if i want to do lsvtec
hi i want to kno whats the best pistons to use on a b18a block for doing lsvtec but still be able to keep it as a daily drivin car in the summer
Old Apr 28, 2004 | 09:38 AM
Karterguy13's Avatar
Default Re: i want to kno whats the best pistons to use on a b18a block if i want to do lsvtec (jspechatch04
type r
Old Apr 28, 2004 | 10:21 AM
joesefcivic's Avatar
CTR...12.5 compression if done right.
Old Apr 29, 2004 | 05:59 PM
99lsvtecauto's Avatar
Default Re: (joesefcivic)
ctr pistons are like ne were from 12:5-12:8:1
Old Apr 30, 2004 | 05:34 PM
milton's Avatar
pr3 pistons will be good for street driven ctr will raise the compression too high so that'll be more gas for you = more$$
http://www.c-speedracing.com/h...c.php
check this site for more info on piston compressions- The compression will be higher than the type r's
Old Apr 30, 2004 | 07:46 PM
dwchkypmp20's Avatar
yea pr3's are good ****....run them with a ctr intake cam and some minor bolt ons and youll rip **** good luck
Old May 1, 2004 | 03:08 PM
corey's96GSR's Avatar
If you are going allmotor then go with ctr pistons but if you want to go boost then stick with some ls pistons.
Old May 1, 2004 | 06:41 PM
I3ackfire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joesefcivic &raquo;</TD></TR><TR><TD CLASS="quote">CTR...12.5 compression if done right.</TD></TR></TABLE>
He said "daily driver", I dont think it is a good idea to have Compression over 12.3 for a daily driver, that goes escpecially for the Ls Vtec, use the B16 pistons, for a safe compression rate!
Old May 2, 2004 | 08:31 PM
Default Re: (I3ackfire)
if u want r pistons get itr pistons ctr is 2 high for daily driving everything would have to be perfect fuel,timing,plugs,etc. Don't Risk it !
Old May 17, 2004 | 01:33 PM
CivicHatchback14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto &raquo;</TD></TR><TR><TD CLASS="quote">if u want r pistons get itr pistons ctr is 2 high for daily driving everything would have to be perfect fuel,timing,plugs,etc. Don't Risk it !</TD></TR></TABLE>
DUHH!
Old May 17, 2004 | 04:35 PM
Default Re: (CivicHatchback14)
i tried the ctr i had 2 sell them before i could even get them in they leave no room for error in your tuning
cleanem1509
14
Feb 1, 2010 08:27 AM
91redteg
Oct 30, 2007 09:11 AM
CeeJayy
11
Dec 9, 2006 02:13 PM
delsol31603
Feb 15, 2005 01:13 AM
Jmorin
12
May 29, 2004 02:30 PM
