oil on top of piston? what does that mean?
Old Nov 1, 2001 | 01:39 PM
DuNkiN's Avatar
New User
Default oil on top of piston? what does that mean?
i need some help, i got oil on top of my piston but my spark plugs are still dry. i was low about 1 and a half quart of oil every 2500 miles. anyone have any ideas? im thinking its a ring but i was also told it could just be a seal or gasket??
thanks
Old Nov 1, 2001 | 01:40 PM
H23 Power's Avatar
Default Re: oil on top of piston? what does that mean? (DuNkiN)
i think it could be a seal in the head...or bad rings on the pistons
Old Nov 1, 2001 | 03:17 PM
mingchi96
Guest
Posts: n/a
how do you know there is oil on your piston? Did you look through your spark plug hole? If you see black deposits, that is normal. All piston tops will accumulate slight carbon deposits. Run a fuel additive through your motor preferably Regan by Penzoil. About you losing oil, it might be your rings, or your avle seals. Try going with a thicker oil.
Old Nov 1, 2001 | 03:22 PM
FSTASNTZ's Avatar
Do a leak down to see where it is coming from.
Is it possible the seals around the plug portion of valve cover are bad?
Jason
Old Nov 1, 2001 | 10:25 PM
DuNkiN's Avatar
New User
Default Re: oil on top of piston? what does that mean? (mingchi96)
yeah i looked thru the hole to see it. Im sure it wasnt carbon because the first 3 only had little patches of wet spots but the whole 4th one was wet. I've tried a fuel additive already with my last oil change and it didnt seem to make a difference. I dont want to use a thicker oil because i dont want a "quick fix", i'd rather not **** it up anymore than it already is. im gonna take it to a shop tm and have them look at it...thanks for the replies.
PS. how much does a leak down go for? i've never had to do one before so im clueless...
Old Nov 2, 2001 | 06:43 AM
mingchi96
Guest
Posts: n/a
A leakdown test is actually a very simple procedure, but most shops charge you about $70 to do it. If you know a shop well, usually they'll do it for free.
joss731
Sep 15, 2010 08:50 AM
Hill4589
Apr 10, 2009 04:56 PM
doublej7584
Feb 17, 2008 07:10 PM
SIXTY-1HATCH
Jan 4, 2007 04:42 AM
Takumi Fujiwara
Feb 23, 2006 08:18 AM
