LS rods Vs stock D16 rons, a TRUE replacement?
ive read up that if i get the LS rods to go into a d16, that i would need to modify them slightly and grind here and there
how much truth is there to this? i was under the assumption that its a DIRECT replacement and that no mods would be needed.
also i would assume stock d16 rods are lighter than the LS rods, if i dont plan on making more than 160 hp, but plan on making it high revving ( 7500-8000) would simply shot peening them be enough?
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i talked to my builder about it, i also did a bit of research about as well.
aside from machining the big end of the rods to fit on a narrower crank journal you have to re-bush the small end for a D series wrist pin. the only way to mate the rods and the pistons would be to have the wrist floating, which means either aftermarket pistons or machining OEM pistons. i analyzed the cost involved and decided that ARP rod bolts would be enough for my application
stan
stan
define "home garage"
if you have a lathe, milling machine a press and precision measuring instruments then yes.
stan
stan
low&slowef
Jan 26, 2011 07:36 PM
Deco989
27
Jan 13, 2011 05:24 PM
RACEPAK
Jul 14, 2007 06:49 PM
