ecu question
Old Apr 27, 2004 | 11:01 PM
meanTheDope's Avatar
Default ecu question
if i am using a p28 ecu off of a 93si and running it on my 92 vx d15z1 motor...would that mess up my motor because its throwing a ecu code, but when i put back the original vx ecu it runs normal with no check engine light. Although with the p28 si ecu it pulls hard and I finally can feel my vtec kick in. What would be best? thanks
Old Apr 27, 2004 | 11:12 PM
The King's Avatar
well what wiring harness are you using ?? do you have the complete vx motor with the egr system and the different o2 sensor , if so i would reccomend finding a ex / si wiring harness , put a ex/si intake manifold on (so you can get rid of the egr system ) and then try the p28 but you will need a 4 wire 02 , feel free to pm me with any more questions , i went threw this in my sedan when i had a vx motor in there
I used a vx motor with , si intake and exhaust manifolds , a ex/si wiring harness , and a p28
and an adjustable fpr
yeah and for the note vtec roars on this sohc with this setup , loudest vtec in a sohc
Old Apr 27, 2004 | 11:22 PM
Default Re: (ReDRoCkEt)
i am using the vx wiring harness...i am thinking about putting in the si intake mani also...how much hp would i gain from these mods? also what is your set up like? hit me up...thanks man
Old Apr 27, 2004 | 11:41 PM
The King's Avatar
i highly reccomend using the ex/si wiring harness , so you can remove the egr system
Old Apr 28, 2004 | 08:35 AM
bump
Old Apr 28, 2004 | 08:51 AM
Jokerluv's Avatar
will a D16A6 intake man fit on the D15Z1?
Old Apr 28, 2004 | 08:58 AM
Default Re: (Jokerluv)
yup
URBAN TANK
Jun 22, 2004 10:44 AM
Import13alla
May 28, 2004 06:37 AM
dremmel
Mar 1, 2004 09:17 PM
whoobeedoobee
Aug 10, 2003 07:41 PM
UltRaH22
Apr 8, 2003 10:12 PM
