My hatch is running lean
Old Apr 27, 2004 | 10:19 PM
SPEEDQUEST INC.'s Avatar
Default My hatch is running lean
I got a 92 EG with a stock b18b (I/H/E) with no cats. Last weekend we Put it in the dyno and is running really lean, I have an Air Fuel gauge and it says is lean too. The check engine light doesn't come on for a few minutes, but after driving it if I stay on the gas for more than 1 minute or so it comes on, but when turn off my car and turn it on again it doesn't come on until I drive it again. I still have the stock 1.5 fuel pump in it, and I just changed the fuel filter too.
Does anybody knows what might it be?... I think is either the fuel pump or the O2 sensor, but I dont want to spend all that money for no reason so, If you guys know what it might be, please let me know... thanks in advance!!
Old Apr 27, 2004 | 10:27 PM
Civiclx's Avatar
Default Re: My hatch is running lean (SkunkEG)
probably the 02 sensor, have you checked the cel?
Old Apr 27, 2004 | 10:30 PM
Default Re: My hatch is running lean (Civiclx)
No I havent checked it yet... do you think the stock 1.5 pump is ok..??
Old Apr 28, 2004 | 09:09 AM
MAKAROV's Avatar
your fuel pump should be fine, it could be that your injectors are spraying irregular
(if there are alot of carbon deposite buildups, it could cause this)
try a fuel induction cleaner, it sprays right into the throttlebody while running
it is also likely to be your o2 sensor like he said check the cell
Old Apr 28, 2004 | 10:39 AM
spoonbenny's Avatar
o2 sensor, or fuel filter is clogged, or if you have a adjustable fuel pressure regulator, turn that bitch up.
One of my boy's had that same problem, he just got a BOSCH o2 , sensor, your stock fuel pump, should be fine, unless your runnin' some hardcore ****.
1sikhatch
Dec 31, 2009 02:11 AM
Import_2
Oct 23, 2008 08:35 PM
BAnnedx3
Jun 18, 2007 12:24 PM
hotinteggy
Oct 15, 2004 07:10 AM
integranator
Aug 3, 2003 09:11 AM
