Fuel Pump Going out??
Old Aug 3, 2003 | 08:07 AM
integranator's Avatar
Default Fuel Pump Going out??
How would i know if my fuel pump is having problems??? I just recently started running lean, and I have no idea why?! I just recently replaced my o2 sensor w/ a brand new bosch one and it still hasn't changed. Someone mentioned to me that it might be my fuel pump-- I have a walbro 255
Old Aug 3, 2003 | 08:52 AM
preluder's Avatar
Default Re: Fuel Pump Going out?? (integranator)
do you have bucking problems with the car not having enough problems . Is the timing on-point? check your plugs and your wires ,fuel filter may be bad . If your reading it from of the a/f ratio guage then your wrong cuase its just a light show unless you have a wideband o2 sensor. and last but not least check the fuel pump relay.
Old Aug 3, 2003 | 09:11 AM
Default Re: Fuel Pump Going out?? (preluder)
the car doesn't buck at all, it kind of stutters every now and then around the 2.5k to 3kish area--- I haven't touched my timing, but i'll check it. Plugs are brk 7e's, wires are decently new. Haven't changed the fuel filter yet, and i've got about 67k on the car. I don't have an a/f guage for the same reason that you've said. The fuel pump is on, because I can hear the whining of it. But where is the pump relay at? Also, when I check the plugs they always look brand new, w/ some signs of lean-ness on them.
ONE-CAM-EF
Jul 26, 2008 10:38 PM
xtegb16x
Oct 30, 2005 12:20 PM
ruah_23
Nov 27, 2004 05:41 AM
birds_sol_94
Aug 24, 2004 12:04 PM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
