CAR WONT START
Old Apr 27, 2004 | 08:14 PM
C-REX 88's Avatar
Default CAR WONT START
I PUT A D16Y7 HEAD ONTO MY D15B6 BLOCK BUT THE CAR WONT START NOW. IT HAS NO CHECK ENGINE LIGHT. I HAVE THE D15 INTAKE MANIFOLD ON IT RIGHT NOW SO EVERYTHING JUST PLUGGED IN. MOTOR TURNS OVER BUT WONT START. I CHECKED THE FUEL LINES AND PUMP. THE SPARK PLUGS ARE ALSO FINE. ALSO A FLAME SHOT OUT OF THE HEADER WHEN I TRIED TO START IT ONCE. IM NOT GOING TO MESS WITH IT UNTIL I FIND MORE OUT. ANY INFO WOULD HELP
Modified by C-REX 88 at 5:52 AM 4/28/2004
Old Apr 27, 2004 | 08:53 PM
Redline130's Avatar
Default Re: CAR WONT START (C-REX 88)
Did you check to see if you are getting spark at the sparkplugs? Is your timing set right? All your connectors are plugged in? All grounds securely attached?
Old Apr 27, 2004 | 10:29 PM
Project99EK's Avatar
Default Re: CAR WONT START (Redline130)
i was there with him trying to figure it all out. his grounds are all secure as far as i know the 3 that there are and he his getting spark i checked each plug on the dizzy by grounding it while he tryed turning it over. as far as the timing im not sure.
Old Apr 28, 2004 | 09:10 AM
Redline130's Avatar
Default Re: CAR WONT START (Project99EK)
Set the motor with cylinder #1 at TDC. Then see if the cam gear is in it's correct position when it's supposed to be at TDC. Basically you need to see if the head and the bottom end are in correct timing with each other. If not, your car will not start.
Old Apr 28, 2004 | 09:44 AM
mr. carpenter's Avatar
yes... cuban b
Old Apr 28, 2004 | 10:47 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Set the motor with cylinder #1 at TDC. Then see if the cam gear is in it's correct position when it's supposed to be at TDC. Basically you need to see if the head and the bottom end are in correct timing with each other. If not, your car will not start.</TD></TR></TABLE>
EXACTLY, CHECK THIS AS YOU ALREADY STATED YOU CHECKED ALL THE OTHER THINGS AND THEY TURNED OUT OK. AND TAKE YOUR CAPS OFF CUZ YOU'RE YELLING
Old Apr 28, 2004 | 12:50 PM
i have another question does he need to switch out to the d16y7's ecu or no?
Old Apr 28, 2004 | 01:45 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-REX 88 &raquo;</TD></TR><TR><TD CLASS="quote">I PUT A D16Y7 HEAD ONTO MY D15B6 BLOCK BUT THE CAR WONT START NOW. IT HAS NO CHECK ENGINE LIGHT. I HAVE THE D15 INTAKE MANIFOLD ON IT RIGHT NOW SO EVERYTHING JUST PLUGGED IN. MOTOR TURNS OVER BUT WONT START. I CHECKED THE FUEL LINES AND PUMP. THE SPARK PLUGS ARE ALSO FINE. ALSO A FLAME SHOT OUT OF THE HEADER WHEN I TRIED TO START IT ONCE. IM NOT GOING TO MESS WITH IT UNTIL I FIND MORE OUT. ANY INFO WOULD HELP
Modified by C-REX 88 at 5:52 AM 4/28/2004</TD></TR></TABLE>
Yeah, if its backfiring timing is off. Is your cap/rotor good?
Old Apr 28, 2004 | 02:14 PM
C-REX 88's Avatar
Thanks for the info. Thanks for the diagram too, now i know where the caps lock button is.
Old Apr 28, 2004 | 04:42 PM
C-REX 88's Avatar
I checked the timing and its fine. The car still wont start i dont know what else it could be.
Old Apr 28, 2004 | 06:21 PM
TrueNorthStar's Avatar
fuel? Are the injectors hooked up? what injectors do you have in there?
Old Apr 28, 2004 | 07:02 PM
C-REX 88's Avatar
Default Re: CAR WONT START (TrueNorthStar)
i got the d15 injectors. they are all hooked up though. i think its something with the distributor
Old Apr 28, 2004 | 08:53 PM
what distributor are you using? I'm not sure if it matters, but it is a possiblity.
You should use the same dizzy/ecu combo.
Old Apr 28, 2004 | 09:04 PM
C-REX 88's Avatar
i used the d15 dizzy, i dont really know either. I'm so frustrated that im just giong to put a d15b in there. It will be faster anyways.
Old Apr 29, 2004 | 01:26 AM
mustbenu's Avatar
actually if its backfiring it doesnt nessacarily mean its off timing..... depending on if it backfires on the accel of decel it can be either fuel or spark...
Old Apr 29, 2004 | 06:47 AM
crx_88_si's Avatar
you have the plug wires on the right spot on the cap?
Old Apr 29, 2004 | 08:38 AM
Default Re: (crx_88_si)
ya the wires are on the right spot according to the manual hes using ...haynes =p
Old Apr 29, 2004 | 08:55 AM
Redline130's Avatar
Default Re: (Project99EK)
Is fuel getting to the injectors? Are there any codes on the ecu?
Old Apr 29, 2004 | 02:54 PM
Default Re: (Redline130)
no codes that i know of and yes i would think fuel is getting to the injectors because it was shooting fuel outta the fuel rail when he forgot to put the washers on originally =p
Old Apr 29, 2004 | 06:03 PM
Big Bird's Avatar
ignitor could be bad in the distributor, or the wire going to the ignitor....I had that problem before, just had to resplice a wire.
Old Apr 29, 2004 | 08:41 PM
C-REX 88's Avatar
Default Re: (Big Bird)
i have no ecu codes but when i turn the distributor to the left it backfires more.
91daINTEGRAda91
Apr 5, 2008 04:32 PM
black6gen
Mar 16, 2007 08:04 PM
stunt_driver
Jun 8, 2005 04:55 AM
dumpeDc2
Dec 30, 2004 09:25 PM
wannab20hatch
13
Dec 3, 2003 04:22 AM
