How to work an ohm meter?
Old Apr 27, 2004 | 01:50 PM
imlachg1's Avatar
Default How to work an ohm meter?
I went out and bought one, and I have no clue how to use it? I want to check my tps sensor to see if it is any good, and have no clue where to put the ****? also I stick the red one in the middle wire on the tps, but where does that black go?
Old Apr 27, 2004 | 02:42 PM
nub's Avatar
nub
Default Re: How to work an ohm meter? (imlachg1)
set the **** to 12v dc not ac. the red probe goes to the center wire and the black goes to ground, metal on vehicle or batt. ground. youll be checking for voltage not resistance (ohms). should show about .45 volts with the key on and throttle closed and 4.5 with the throttle wide open.
fear45
Jan 8, 2019 12:26 PM
bmiller17
22
May 19, 2013 05:54 PM
Jae fillz
Nov 20, 2011 07:46 PM
Powered by VTEC
Jan 30, 2008 10:06 AM
civicmon
Jul 24, 2004 05:55 PM
