Ignition coil
Old Apr 27, 2004 | 01:42 PM
pacifico's Avatar
Default Ignition coil
I just got my new coil today for my 00 si and was wondering if theres any tips on how to install this. I plan on doin it tomorrow so any help would be appreciated.
thanks
Old Apr 27, 2004 | 02:27 PM
91DA9's Avatar
Default Re: Ignition coil (pacifico)
It's pretty straightforward. Just follow the instructions in the manual (Helms, Haynes) and it should be pretty easy. It would probably be easier if you took the distributor off the car.
Old Apr 27, 2004 | 02:59 PM
pacifico's Avatar
any1 else?
Old Apr 27, 2004 | 03:14 PM
pacifico's Avatar
Default Re: (pacifico)
Do I have to worry about messing up the timing?
Old Apr 27, 2004 | 03:39 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pacifico &raquo;</TD></TR><TR><TD CLASS="quote">Do I have to worry about messing up the timing?</TD></TR></TABLE>
only if you take the distributor off the block
Old Apr 27, 2004 | 06:54 PM
showtymers619's Avatar
* B A N N E D *
Default Re: (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
only if you take the distributor off the block</TD></TR></TABLE>
not even that.. the distributor only goes in 1 way...
when you open it all up....you will see 1 screws that holds it in.. and then you will see the positive and negative wires on it the just replace it
importdreamer
Jul 24, 2008 12:29 PM
okbubbac
May 28, 2007 05:29 AM
Thepanda
Dec 11, 2005 10:03 AM
Creepin4DR
Mar 6, 2005 02:11 PM
uNF$@#!
Mar 28, 2004 11:48 PM
