crx b16 = no start
Old Apr 27, 2004 | 12:48 PM
super8's Avatar
Default crx b16 = no start
i did a search didnt really find anything that helped, we have a 91 crx si w/ a b16 swap, the problem is a no start hot conditon that im having a hard time tracing down. when the engine is cold the car starts up and runs no problem, after you drive it around and the engine reaches operating temprature, and you shut it off, it will not restart, it just cranks and cranks but will not start until you let it cool off. and also intermittantly the vtec cuts out and rev limiter kicks in at about 4,000rpm. but im not sure they are related. my biggest concern is the no start concern. ive replaced the main power relay and the fuel injector pulse regulator. next thing im going to check is the crank sensor/wiring. havent touched since the fall. time to start up again. any help would be appreciated.
~~~not sure if i posted this in the right place, its is a swap, but its also a tech question, so maybe should be moved to tech..............
Modified by super8 at 10:02 PM 4/27/2004
Old Apr 28, 2004 | 07:05 AM
super8's Avatar
Default Re: crx b16 = no start (super8)
anyone?
furmanalone
May 24, 2007 10:31 AM
SkiLLzMiKE
Dec 14, 2006 06:09 PM
hybridhatch07
Aug 6, 2006 04:01 PM
Hype-S
10
Jan 6, 2006 01:57 PM
Amalgam
Dec 7, 2003 09:10 AM
