CRX: Hood doesn't pop smoothly
Old Apr 27, 2004 | 11:49 AM
B2FiNiTY's Avatar
Default CRX: Hood doesn't pop smoothly
I have to pull the latch all the way to the top till the hood pops. Sometimes it doesn't even have to pop and I have to play with the wire.
Does this mean the cable is stretched and I have to get a new one or is there something with the latch itself?
Right now when I pull on it, it makes a quick short click sound but the hood doesn't pop or budge.
Old Apr 27, 2004 | 11:51 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
my latest technique has been pull very hard on the trunk latch and punch the hood, usually works
Old Apr 27, 2004 | 12:04 PM
B2FiNiTY's Avatar
Default Re: (91siredrex)
I just tighted up the cable near the front of the latch by the hood so that it has less slack. Pops a lot better now.
How can one tell if the problem is with the cable or the latch?
Old Apr 27, 2004 | 12:33 PM
Frederz's Avatar
Default Re: (B2FiNiTY)
i have the same problem
Old Apr 27, 2004 | 04:23 PM
bucketheadCRX's Avatar
Default Re: (Frederz)
oh boy..the old "stretched cable" routine..ive used a pair of pliers for my "latch lever" for the past 2 years damn my laziness..i just grab that little barb on the end of the cable and tug..pop-ola
Old Apr 27, 2004 | 04:38 PM
Spooled1.6L's Avatar
Default Re: (buckethead36)
mine too, sometimes she pops, sometimes I get nothing. The cable is really frayed and probably needs to be replaced. But... I just pull like Im gonna open it once, then bang on the hood right above my "H" and then try and open it again and she pops right open, Everytime
Old Apr 27, 2004 | 05:32 PM
Austin's Avatar
Default Re: (Spooled1.6L)
Sounds like my hood
Old Apr 27, 2004 | 05:42 PM
ljoe's Avatar
Default Re: (Austin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like my hood </TD></TR></TABLE>
my old one too...
Old Apr 27, 2004 | 06:43 PM
B2FiNiTY's Avatar
Default Re: (ljoe)
So you guys think it's a worn hood latch cable? That thing is $30 something bucks
Old Apr 27, 2004 | 06:50 PM
Nic's Avatar
Nic
i have the same problem with mine right now. I will see what it takes to fix mine and post it up here.
$30 is not all that bad
Old Apr 27, 2004 | 07:31 PM
Tyson's Avatar
Default Re: (stk crx)
its not necessarily the cable. you can try lubricating the latch, as well as adjusting the height of the spring on the hood to play with the action of the latch. it usually fixes the problem.
Old Apr 27, 2004 | 07:43 PM
APEX CRX's Avatar
Default Re: CRX: Hood doesn't pop smoothly (B2FiNiTY)
usually is the cable. you can adjust the hood latch a certain amount but after like what 15 years that cable is bound to stretch
Old Apr 27, 2004 | 07:46 PM
B2FiNiTY's Avatar
Default Re: CRX: Hood doesn't pop smoothly (APEX CRX)
I'll pick up a new cable tommorow probably. I like having the hood pop on command. Just one of those things that bugs.
Old Apr 27, 2004 | 07:54 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I'll pick up a new cable tommorow probably. I like having the hood pop on command. Just one of those things that bugs. </TD></TR></TABLE>
it does help that your hood opens when you want to, like maybe in case of an engine fire? LOL
Old Apr 27, 2004 | 08:43 PM
B2FiNiTY's Avatar
Don't even start with that
Old Apr 27, 2004 | 10:48 PM
importboi22's Avatar
the best technique right here ill let you guys in on it
with your door all the way open and your body standing were the door and body meet, reach down with your right hand and pull the latch while doing this reach over with your left hand, open you hand to a flat palm style and gentley or with moderate force tap the corner of the hood, then VOILA! opened hood
Old Apr 28, 2004 | 11:18 AM
Austin's Avatar
Default Re: CRX: Hood doesn't pop smoothly (importboi22)
I just consider it an extra anti-theft device...hood doesn't open.
Austin
Old Apr 28, 2004 | 11:40 AM
shaddr3's Avatar
Default Re: CRX: Hood doesn't pop smoothly (Austin)
My cable didnt work even wehn I bought the car, gotta lvoe the racing style clips!
Old Apr 28, 2004 | 01:08 PM
ls_vtec_crx's Avatar
haha what importboi22 said is what i do ....super stealth for the theives....its funny yet shamefull at the same time...but idont care too much..i just tell someone else to bang the front for me....
also someone said you can screw the piece on the hood in more and that'll work but mines is as tight as heck so i donno
Old Apr 28, 2004 | 01:09 PM
B2FiNiTY's Avatar
Default Re: (ls_vtec_crx)
What does banging on the hood do?
Old Apr 28, 2004 | 01:25 PM
regime's Avatar
i had to have someone push down above the H some times to get my old one open.
just one of the lil things to deal with as a crx owner =D
pinecone
May 16, 2006 05:56 PM
sinfultrends
Dec 29, 2005 11:51 PM
ZCHF
31
Mar 15, 2004 06:20 PM
naterpatater77
Feb 29, 2004 05:32 PM
cannan
Dec 28, 2003 09:40 AM
