PCV on b20 vtec
Old Apr 27, 2004 | 10:22 AM
showtymers619's Avatar
* B A N N E D *
Default PCV on b20 vtec
the b20's dont have it behind the block. it has it on the valve cover.. im using a 99 SI head.. what do i do?
tap a hole in the valve cover?
for damm sure i dont ahve to drill in the back of the block
Old Apr 27, 2004 | 06:39 PM
* B A N N E D *
Default Re: PCV on b20 vtec (ShowTymers619)
up
Old Apr 27, 2004 | 10:21 PM
H2nr's Avatar
yes, drill and tap a 1/8" hole in the back of the block. then drill a hole in the top of a universal catch can for the PCV and run a line from the PCV to the mani. Run a line from the fitting you put in the back of the block to one of the fittings in the top/side of the can. Drain can once every few weeks.
Old Apr 28, 2004 | 06:32 AM
* B A N N E D *
Default Re: PCV on b20 vtec (H2nr)
man that sounds like a hassle. LOL
Old May 1, 2004 | 09:21 PM
slowazzhatch's Avatar
Default Re: PCV on b20 vtec (VtecKillsDA)
tapped mine into the top of the valve cover, works great!
Todallybuilt
Jan 15, 2016 03:31 AM
joiv21
May 4, 2013 08:34 AM
TravisBiggie
Jun 23, 2012 07:40 PM
akandok
18
Sep 17, 2009 04:21 AM
DrGrEeNtHuMb
Jul 30, 2009 04:30 AM
