Max Psi???
Old Nov 1, 2001 | 06:50 AM
Gearheaded's Avatar
Default Max Psi???
2001 civics have a 9.9:1 compression ratio. What is the max psi for this compression, considering everyday driving?
Old Nov 1, 2001 | 07:26 AM
rtype11's Avatar
Default Re: Max Psi??? (civicman01')
9psi with half assed tuning shouldnt blow up on you too bad.
Old Nov 1, 2001 | 10:35 AM
DLB1994's Avatar
Default Re: Max Psi??? (rtype11)
with that t4 in your icon no more then 10psi on that D17 u may not get boost to 5500 rpms
Old Nov 1, 2001 | 12:20 PM
Gearheaded's Avatar
Default Re: Max Psi??? (DLB1994)
What do you mean??? until 5500rpms??? Please explain in detail, I've never heard of that before
Old Nov 1, 2001 | 12:35 PM
Speed PHreak's Avatar
our little dinky 4 cylinders don't produce enough exhaust flow to spool a turbo that big quickly.........especially a D17. Now an super-double-whack H22 on the other hand might.....
Old Nov 1, 2001 | 11:57 PM
DLB1994's Avatar
Default Re: Max Psi??? (Speed PHreak)
right it wont spool up in to vtec u need a t3 or a t3/t4
Old Nov 2, 2001 | 12:39 AM
liam821's Avatar
A small t3/t4 (.48 ar) with a big exhaust spools very nicely on a d-series honda. Any larger though and its a huge lag monster.
Personally, i think a turbo like a big t28/t28, or a t28/t3 would be awesome on a d-series honda on the street.
liam
Old Nov 2, 2001 | 06:14 AM
VTC_CiViC's Avatar
Default Re: Max Psi??? (liam821)
Or a small T04E as was reccomended to me with a .48 A/R
[Modified by VTC_CiViC, 10:15 AM 11/2/2001]
Old Nov 2, 2001 | 09:42 AM
liam821's Avatar
Default Re: Max Psi??? (VTC_CiViC)
Yep..thats the turbo i have. t3/t04e .48 a/r with a 54 trim. Its a very nice quick spooling still has lots of ***** at high rpm turbo. Awesome for high hp street driven d-series hondas.
I also think it would be a nice on a b16a, although most people run much larger turbos. I really like a quick spooling turbo.
liam
Old Nov 2, 2001 | 10:31 AM
VTC_CiViC's Avatar
Not so much larger, but the A/R would definatley have to be changed to at least .57 or .63 for the 8k+ rpm of a B16.
Casey
Dec 28, 2011 08:06 PM
punkracer
May 2, 2011 07:38 AM
spoolin turbo s
Oct 19, 2008 05:18 PM
graphic
Nov 4, 2003 06:00 PM
Boostless97Lude
May 2, 2003 08:03 AM
