What should I do about the high rpm on highway with S1 tranny in B16A?
Old Apr 27, 2004 | 09:25 AM
kim_2_da_chee's Avatar
Default What should I do about the high rpm on highway with S1 tranny in B16A?
Should I change the fd?
Which fd will work with this tranny?
Should I swap the tranny for Y1? or J1? or YS1?
I love the close gears and how I can constantly stay in vtec through every shift, but the really high rpm is starting to bug me while on the highway... I'm almost in vtec at 120km/h in 5TH GEAR!~
Old Apr 27, 2004 | 09:36 AM
b16_madman's Avatar
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (kim_2_da_chee)
I can't member if you can do the same for your tranny, but for my J1 I swapped in the LS 5th gearset. Here's a kick booty writeup on it.
https://honda-tech.com/zerothread?id=555929
Old Apr 27, 2004 | 09:37 AM
EL Vap133's Avatar
I just put up with it and got a VAFC so I can adjust the vtec on long trips. But then again I have 2 other daily drivers.
Old Apr 27, 2004 | 10:58 AM
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (EL Vap133)
thanks B16_madman, that is a good write up
btw, is the 4.126 stamped on the gear somewhere to know i have the right one?
Old Apr 27, 2004 | 09:44 PM
eda6's Avatar
Get a new chip. I got same setup. VTEC @ 5200. VTEC won't kick in until around 150 km/h.
PR3 ecu.
Old Apr 27, 2004 | 11:38 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I just put up with it and got a VAFC so I can adjust the vtec on long trips. But then again I have 2 other daily drivers. </TD></TR></TABLE>
I run an S1 tranny and my VTEC crossover is at 4900 and I dont have a problem with hitting VTEC in 5th gear. Especially when cruising. Whats that all about? In 5th gear and 75mph I am right ~ 5500. Im not in VTEC the whole time...
Old Apr 28, 2004 | 10:18 AM
chadmasterc's Avatar
Its not hurting the engine cruising at that speed, B16's where meant to rev high.
Old Apr 28, 2004 | 10:39 AM
EL Vap133's Avatar
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">
I run an S1 tranny and my VTEC crossover is at 4900 and I dont have a problem with hitting VTEC in 5th gear. Especially when cruising. Whats that all about? In 5th gear and 75mph I am right ~ 5500. Im not in VTEC the whole time...</TD></TR></TABLE>
When you drive to Vegas you do.
Old Apr 28, 2004 | 10:57 AM
krazie1's Avatar
BANNED
fo sho sucks *** guys
but either deal with it or do something about it
I am upgrading to hydro itr
so I goes I am giving up u can say??? maybe or going u in performance
can we say LSD
Old Apr 28, 2004 | 11:33 AM
temp's Avatar
get an oil cooler for the engine and tranny and be happy
Old Apr 28, 2004 | 12:34 PM
4drEF's Avatar
Keyboard Humorist
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">so I goes I am giving up u can say??? maybe or going u in performance
can we say LSD
WTF? HAhaahahaha!
Have you been hanging out on this site -
http://www.planettribes.com/allyourbase/AYB2.swf
Maybe you are the creator of the site?
I added a few links to some things that I think might be helpful crap for you.
http://writingcenter.mcc.edu/fragment.pdf
http://www.btinternet.com/~tri...i.htm
http://edushop.edu4kids.com/ca...=1383
http://faculty.washington.edu/ezent/imsc.htm
http://www.gmatbuster.org/gmat_sc.htm
I hope that helps. Let me you know if more need links bases are you us for please.
Old Apr 28, 2004 | 12:39 PM
SiRex91's Avatar
Does your S1 have the stock 4.400 fd? If it does, you may need to check your tach. I have a JDM S1 trans on my b16a and at 75mph my Apexi tach shows my revs at ~4500rpm.
The highway mileage on the S1 trans is pretty good. Driving to Vegas a two weeks ago at about 85mph the whole way I calculated high 30's mpg.
Old Apr 28, 2004 | 01:05 PM
RobbieG35's Avatar
12 Years Strong
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (SiRex91)
My J1 is horrible on the highway, but it makes up for it bottom end
Old Apr 28, 2004 | 01:58 PM
VTECRXballa21's Avatar
YS1 tranny is the same way, b16 tranny's have really short gears. Good for quarter mile.
Old Apr 28, 2004 | 02:05 PM
krazie1's Avatar
BANNED
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (VTECRXballa21)
not all are that short but yes try r compared to other models
like tegs and d series
Old May 3, 2004 | 08:29 AM
iskendi's Avatar
I have a 92 integra gsr and when I'm driving 60mph my rpm is 3500 and at 70mph it is at 4000 or so and at 80mph 4500-5000rpm is that normal. It seems very high. The engine seems kind of loud when just cruising on the highway. Could it be that the tranny needs to be rebiult. I also have a 94 integra ls and it does not do this at all on the highway at 60mph it about at 3000rpm's.
COULD ANYONE TELL ME IF THIS IS NORMAL OR NOT. THANKS!
Old May 3, 2004 | 08:40 AM
B2FiNiTY's Avatar
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (iskendi)
That is normal.
Old May 3, 2004 | 08:52 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">Should I change the fd?
VTEC requires more conditions to be met then just rpm.. such as coolant temp,oil pressure and throttle pos.
Old May 3, 2004 | 03:56 PM
twin rex's's Avatar
My j1 is the same way but i give up highway use for quarter mile performance
Old May 3, 2004 | 05:23 PM
AllMotorRandy's Avatar
Default Re: What should I do about the high rpm on highway with S1 tranny in B16A? (twin rex's)
im rocking an s1 and i love it..........i was on an ls tranny for a while and i love the way the vtec tranny feels over the ls. i think lower e.t.'s are worth more than a comfortable ride. just my 2 cents. peace!
husker26
Dec 14, 2006 03:26 PM
Creator
Oct 26, 2004 07:11 PM
j_max420
Jul 11, 2004 12:50 AM
xtremcrx77
Jan 1, 2002 05:13 PM
