Place Racing Front Cross Member Opinions
I only want opinions from first hand experience please
I've been hearing both that they sucks and they are good so someone who actually owns or has owned one please fill me in, i don't care about ground clearance really....
Thanks
Thanks
I had mine for a couple months, it would scrape all over. Then I was about to drive onto the freeway and I heard a loud noise. As I was going to merge, my steering got all sloppy and I heard a grinding noise. My alignment was so messed up I had to drive on the shoulder, get off the freeway, and slowly drive the car back home. Upon inspecting the car, I noticed that the crossmember had broken where the radius rod goes into. Too bad I didn't have a digicam back then or I would have taken pics of the broken piece. I went to Place Racing and they replaced it for free, I then sold it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I had mine for a couple months, it would scrape all over. Then I was about to drive onto the freeway and I heard a loud noise. As I was going to merge, my steering got all sloppy and I heard a grinding noise. My alignment was so messed up I had to drive on the shoulder, get off the freeway, and slowly drive the car back home. Upon inspecting the car, I noticed that the crossmember had broken where the radius rod goes into. Too bad I didn't have a digicam back then or I would have taken pics of the broken piece. I went to Place Racing and they replaced it for free, I then sold it. </TD></TR></TABLE>
well that just deters me from buying it lol thanks for the 411
i guess it's jimfab or whenever fullrace gets theres out yet then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE »</TD></TR><TR><TD CLASS="quote">
i guess it's jimfab or whenever fullrace gets theres out yet then</TD></TR></TABLE>
Yeah man, good thing it happened right when I got on the freeway. Although Place Racing claims that they have reinforced it since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE »</TD></TR><TR><TD CLASS="quote">what cross member do you use now?
do you know if they did reinforce it or not?</TD></TR></TABLE>
They said they did, I sold the new one to a fellow HT member and he had no problems with it, but then he sold it too. I am using the stock crossmember now, don't know if I should get another aftermarket one after that happened.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE »</TD></TR><TR><TD CLASS="quote">hmmmm how much did you get your place racing for? isn't it cheap like 200? or was i mistaken?
Yeah, I got mime for $190.
ah i c
from where if you don't mind me asking?
I might just have to buy it... i guess i can use that until the full race one comes out then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE »</TD></TR><TR><TD CLASS="quote">ah i c
I might just have to buy it... i guess i can use that until the full race one comes out then</TD></TR></TABLE>
I bought it from a local place called "Autolink", but I believe http://www.jhpusa.com sells them too.
I haven't had any problems with mine. It has been on for over a year now. It has scraped before but i don't consider that problem.
From: hittin corners so hard you can taste my rims..
autolink
did that also come with the PLR mount? i belive it did?
</TD></TR></TABLE>autolink
got mines at AUTOLINK also
and have had mine for about 1 yr now and no prob expect u should check ur bolt and nuts every month or so
I lost about 3-4 since last oil change....
and yeah I guess they fix that problemo
but still up to u what u want to have
with the PR crossmember it sets u up for either turbo and a EG radiator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">
autolink
did that also come with the PLR mount? i belive it did?</TD></TR></TABLE>
Nope, mine didn't come with it.
autolink
did that also come with the PLR mount? i belive it did?</TD></TR></TABLE>Nope, mine didn't come with it.
