99 SI sway bar size??? 22mm 24mm?
Old Apr 27, 2004 | 07:01 AM
JDMCRX's Avatar
Default 99 SI sway bar size??? 22mm 24mm?
Hey guys just wondering is it 22mm or 24mm or bigger my EL has a 24mm on it just wondering if the SI uses a 24mm or bigger?
Old Apr 27, 2004 | 07:10 AM
6SPD_EK's Avatar
Default Re: 99 SI sway bar size??? 22mm 24mm? (JDMCRX)
26mm front
13mm rear
*search is your friend* "diameter" or "sway bar" archive topics - eg+/del sol forum
Modified by adirondackR at 11:22 AM 4/27/2004
Old Apr 27, 2004 | 07:36 AM
Nova_Dust's Avatar
I thought it is 26mm front and 19mm back?
I could be wrong.
Old Apr 27, 2004 | 07:39 AM
6SPD_EK's Avatar
Default Re: (Nova_Dust)
see highlighted line
Old Apr 27, 2004 | 07:56 AM
Nova_Dust's Avatar
oh... I thought SIR has 19mm rear sway...
*scratches head*
Old Apr 27, 2004 | 08:00 AM
Dengar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nova_Dust &raquo;</TD></TR><TR><TD CLASS="quote">oh... I thought SIR has 19mm rear sway...
*scratches head*</TD></TR></TABLE>
My friend had his si up on the lift one day and I was shocked to see how small the rear sway was.
Old Apr 27, 2004 | 08:01 AM
JDMCRX's Avatar
so the front is a 26mm for sure cause im going to order the bar my car has a 24mm on it
Old Apr 27, 2004 | 09:14 AM
RiceNmotioN's Avatar
Default Re: (JDMCRX)
yep, 96-up EX's have 24mm in front only, si's have F:26mm R:13mm
Old Apr 27, 2004 | 11:17 AM
JDMCRX's Avatar
Default Re: (RiceNmotioN)
OK COO IM GOING TO ORDER THE FRONT BAR TODAY
Old Apr 27, 2004 | 11:34 AM
EricUSC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceNmotioN &raquo;</TD></TR><TR><TD CLASS="quote">yep, 96-up EX's have 24mm in front only, si's have F:26mm R:13mm</TD></TR></TABLE>
No, the 96-00 EX has a 22 mm bar in the front and no bar in the rear.
Old Apr 27, 2004 | 11:50 AM
JDMCRX's Avatar
Default Re: (EricUSC)
Coo our 1.6EL's come with a 24mm front and a 13mm rear and we use the same setup as the ITR for the front links
Old Apr 27, 2004 | 12:41 PM
my bad, I always mix up EX with the GSR one.
Midori Green
Jun 21, 2008 01:04 AM
shaggyeg6si
May 8, 2008 05:19 PM
chino369
Suspension & Brakes
Feb 26, 2007 12:13 AM
civexspeedy
Aug 25, 2006 02:43 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
