D16Z5 into EK, best ECU?
Old Apr 26, 2004 | 09:54 PM
nismo's Avatar
Default D16A9 into EK, best OBD1 ECU?
Here is the story
Recently ,I swapped d16a9 (DOHC)ZC engine from 91 crx into EK(don`t ask me whay) instead of d16y7 that was completely destroyed.I have chanched the distributor and injectors to obd2 ,and done the wiring.The only thing I did not changed is the ecu,simply becouse I had only obd0 ecu from crx,and I didn`t think it is a greate idea to make it works with obd2 electronics. My question is :what ecu I can use with this particular combo?
Thanks
Alex
P.S. Now I have that 3-wire IACV problem.
Modified by nismo at 12:23 PM 4/27/2004
Modified by nismo at 5:30 PM 4/27/2004
Old Apr 26, 2004 | 11:17 PM
Wazup's Avatar
Default Re: D16Z5 into EK, best ECU? (nismo)
whoa, looks like a typo... do you mean d16z6 (sohc)?
Old Apr 27, 2004 | 03:21 AM
nismo's Avatar
Default Re: D16Z5 into EK, best ECU? (Wazup)
It is not a mistake,I have an European version, I believe in the US it would be eather D16A8 or A9
i-VTEC_do_you
11
Dec 31, 2009 08:11 AM
GSR-TRBO-DA
May 24, 2007 07:30 AM
Boosted96EK
Sep 20, 2004 08:52 AM
AllMotorMark
Nov 3, 2001 11:21 AM
