Rebuilt H22a4 CEL 7 HELP!!!!
Old Apr 26, 2004 | 06:08 PM
ludeboy555's Avatar
Default Rebuilt H22a4 CEL 7 HELP!!!!
I just got finish doing a complete rebuild on the motor...got type s pistons and did all the usual stuff...anyways car starts and is running but I am getting CEL 7...check the throtle sensor...nothing. The rpm would jolt around 3k rpm... Is there something Im missing??? Please help...
Here is list of what I did
Type S os pistons
Rebuild head OEM specs
Bore and Hone
Rebalance Crank
ARP head studs
ACT clutch
Lighten Flywheel 13lbs
All new gaskets
Old Apr 27, 2004 | 09:59 AM
Qfactor's Avatar
Default Re: Rebuilt H22a4 CEL 7 HELP!!!! (ludeboy555)
check your map and tps plugs might be switched around. or check signal at ecu pins and then go from there.
MikeD21
Jun 10, 2015 03:24 PM
skylinerb26dett
Honda CR-V & Element
Aug 19, 2012 05:42 PM
xxwhixx
12
Apr 8, 2006 04:10 PM
cu3tip
Apr 10, 2004 11:28 PM
