Maintenance
Hey I'm new to bikes, only had my gsxr for 6 months. Its a 99 gsxr 600 with 20,000 miles, what do you think I need to do? I have already changed the chain and sprocket, and I am about to put new seals in the front forks. Thanks for your help.
Kris
Kris
Do all the regular checks (also check the manual)... check the tires, bolts, fluids, oil, cable assemblies for wear, maybe run a compression test if possible and check the clutch.
I am sure you need to do a valve adjustment. Also check your head bearings, fork seals and change your fork oil. Get a can of Seafoam and follow the directions on the can.
jokerstud
Dec 22, 2002 08:27 PM
