Clutch problem? Please help
Hey guys I just got my type r a few weeks ago and all seems well so far. Although in the past couple days ive noticed that after I drive the car for more then 30 min or so, the clutch makes a creecky squeeking sound everytime u press it down. This includes when the car is running and off. However, when I park the car and leave it off for awhile (overnight), the creecking sound goes away. But right when I drive the car again for about 30 min, it comes back. Any ideas?
The pivot ball for the clutch fork tends to get dry and make noise. You can try pulling the boot back and spraying lube onto it, but the best way is to lube it when you have the tranny out. Honda Urea grease works great there and on the input shaft.
I have noticed the exact same issue. My clutch feels crunchy though, it's not just sqeaking or making noise. Might be a different issue.
I've also had very inconsistent (mushy) clutch engagement on occasion, and I think I've got a leaky slave cylinder in the mix too. Off to the dealer on Thursday...
Bingo! This was definitely the case for mine!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">The pivot ball for the clutch fork tends to get dry and make noise. You can try pulling the boot back and spraying lube onto it, but the best way is to lube it when you have the tranny out. Honda Urea grease works great there and on the input shaft.</TD></TR></TABLE>
reeder321
Apr 1, 2004 01:47 PM
