Pressure drop on a Geeser Turbo
Old Oct 31, 2001 | 08:59 PM
meanteg's Avatar
New User
Default Pressure drop on a Geeser Turbo
I have a 97 GSR with Greddy Turbo. With the boost at 8 pounds everything is fine. But at 10 pounds the boost drops gradually from 10psi at 4000 rpm to 8psi at 8000 rpm.
Two things might explain that problem.
1- tiny 2" downpipe with 2.25" exhaust. (cat removed)
OR
2- Too much overlap... -i'm still using the stock cam gears
Wich one of these 2 choices can cause my problem? maybe both? or something else?
[Modified by meanteg, 6:00 AM 11/1/2001]
Old Oct 31, 2001 | 09:13 PM
RTEK's Avatar
New User
Default Re: Pressure drop on a Geeser Turbo (meanteg)
your engine effeciency may be the cause of your problem
valve overlap is out of the question
have you tried re-installing the cat?
that "greedy" kit was designed for cat use
you may be lossing too much back pressure
good luck
Old Oct 31, 2001 | 10:00 PM
RTEK's Avatar
New User
by the way contact "GREEDY"
that turbo is internally/integrally regulated
the waste gate may be set for less than 10 psi
Boosted67
Aug 26, 2016 07:04 AM
boosted03
Apr 2, 2013 05:34 PM
rickturboteg
Aug 27, 2006 09:23 AM
Maxime
Oct 17, 2003 06:46 AM
1.8T_EG
Jul 21, 2003 05:01 PM
