SiR 1 vs SiR 2 oil cooler
Hey,
a buddy of mine bought two B16s (an SiR I and an SiR II). The SiR 1 had an oil cooler, but the SiR 2 did not. Anyone know anything about this?
For the record the oil filter stud screws out of the Ls block and you can thread an oil cooler in there. Just use a vice grip with a good grip and turn. It'll come out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- »</TD></TR><TR><TD CLASS="quote">Hey,
correct, honda got a little cheaper and took the oil cooler off in 92+
like the 90-91 b16's had them... the 94-95 GSR's had them
then 96+ GSR no longer has them
ALL type R's have them
all dohc VTEC B series engines have the hole threaded... on a LS or B20 the casting mark is there but you need to drill and tap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 »</TD></TR><TR><TD CLASS="quote">
he just said that the ls stud IS threaded.
I was there, the stud threaded right out of an LS block.
am I missing something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 »</TD></TR><TR><TD CLASS="quote">
am I missing something?</TD></TR></TABLE>
he means for the coolant hose coming out of the oil cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">
he means for the coolant hose coming out of the oil cooler</TD></TR></TABLE>
thx
yah take a pipe wrench... that works best for me to remove the old oil filter threads.
Thread in the factory oil cooler and poof your done... all bolt on process if your DOHC VTEC'd out.
Mind you if you want to BUY all the parts from the stealership its 400 bux
If you want a complete kit from me=70 bucks shipped
i got 5 kits in stock
thx
