look at alignment sett.wtf?
Old Apr 26, 2004 | 07:52 AM
mmuller's Avatar
Mad Scientist
Default look at alignment sett.wtf?NEW settings LOOK
Alright, got my car aligned and im still EATING the inside of the tires up,it eats them up in no time....wtf...
Caster, is all messed up, would that cause tire wear?i know it usually doesnt, but its soo messed up that i dont know..
Im going to try swapping front upper control arm since i heard they'll give you like 3 degrees more caster.
the car has been in a big accindent before and i know the frame is bent, but its not worth for me to spend $1000 to get it to a frame machine.I just want it not to eat my tires anymore.
edit:STOCK suspension
Analyze this:
help
OK GOT NEW ALIGNMENT TODAY
little of specs:
-since the alignment above i lowered the car with eibach sportlines(1.8?)
-i also switched upper control arms since my caster was all fucked cause of the subframe being bent.Well, what a difference...the car feels a lot more stable now; even though steering effort is greatly increased(no ps). but at least is closer to specs.I can also say that they add 3 degrees of caster.
-Used 1 washer on the back for camber and it worked great
well, after the alignment was done the car STILL pulls to the right A LOT. i know that the difference in caster makes the car pull to the right a little, but this much????I mean its only .7 degrees difference...
why is my car still pulling to the right?
HELP, or im going into a nervous breakdown and going to start burning my car piece by piece so it suffers...
Modified by mmuller at 10:49 PM 4/27/2004
Modified by mmuller at 10:52 PM 4/27/2004
Old Apr 26, 2004 | 08:13 AM
GSRswapandslow.
Guest
Posts: n/a
1994 type r...haha, sorry but that's funny
Old Apr 26, 2004 | 08:18 AM
MattD@Stoptech's Avatar
Default Re: (Ej6andslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow &raquo;</TD></TR><TR><TD CLASS="quote">1994 type r...haha, sorry but that's funny</TD></TR></TABLE>
j00 don't know what "ex." means do j00
Old Apr 26, 2004 | 08:50 AM
Thrillhouse's Avatar
ex = EXCEPT
and no caster wont jack up your tires, all caster does is either cause your car to pull or push, making it harder or easier to steer. Get under neath your car and start grabbing ball joints and checking for wear, then check for bent tie rods, and any loose bushings. Is your steering very loose or has a lot of play, then check your rach and pinion for worn or loose connections to the firewall ( I think thats where it is). Hopefully I helped a little.
Old Apr 26, 2004 | 08:55 AM
Default Re: (Thrillhouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse &raquo;</TD></TR><TR><TD CLASS="quote">ex = EXCEPT
and no caster wont jack up your tires, all caster does is either cause your car to pull or push, making it harder or easier to steer. Get under neath your car and start grabbing ball joints and checking for wear, then check for bent tie rods, and any loose bushings. Is your steering very loose or has a lot of play, then check your rach and pinion for worn or loose connections to the firewall ( I think thats where it is). Hopefully I helped a little. </TD></TR></TABLE>
I 2nd that motion. Something is either broken, or loose. The static alignment numbers look ok, but once the car is rolling or turning the wheels get pulled out of alignment and hence the tire wear...
thats my guess
Old Apr 26, 2004 | 09:40 AM
GSRswapandslow.
Guest
Posts: n/a
his subframe is bent.....that's what we're thinking the whole problem is
and i saw the "ex" but i had to rip on him about somethign
Old Apr 26, 2004 | 10:40 AM
MightyMouseTech's Avatar
Default Re: (GSRswapandslow.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. &raquo;</TD></TR><TR><TD CLASS="quote">his subframe is bent.....that's what we're thinking the whole problem is
Not just bent, the whole subframe is pushed BACKWARDS towards the rear of the car, and not just a little either.
The only way you are going to fix this is to put it on a frame straightener and install a new subframe. Might be cheaper to sell the car and get another one. The thing must wander all over the road with that much negative caster.
Old Apr 26, 2004 | 10:51 AM
APEX CRX's Avatar
Default Re: (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">
The thing must wander all over the road with that much negative caster.</TD></TR></TABLE>
yeah like a crab stoned on weed
Old Apr 27, 2004 | 06:50 PM
mmuller's Avatar
Mad Scientist
Default Re: (APEX CRX)
TTT
since new alignment is done and still fuecked
Old Apr 28, 2004 | 04:56 AM
mmuller's Avatar
Mad Scientist
Default Re: (mmuller)
Old Apr 28, 2004 | 05:18 AM
It will stay that way until you fix the unibody and the beam.
Old Apr 28, 2004 | 07:52 AM
mmuller's Avatar
Mad Scientist
so anybody know if that difference in caster will pull the car to the right so much?
i let go of the steering and the car just turns right...
Old Apr 28, 2004 | 08:23 AM
Are you dense?
Old Apr 28, 2004 | 10:12 AM
crxgator's Avatar
Default Re: (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Are you dense?</TD></TR></TABLE>
lol...
the answers have been posted...fix the subframe, or sell the car...
Old Apr 28, 2004 | 11:04 PM
Louie's Avatar
What would Chente do?
Default Re: (crxgator)
If possible fix your camber. Not much you can do about the caster values but both camber and caster are biased toward the right. Decreasing the left camber 1 degree(making it -.4 now) should reduce the pull to a drift. Good luck and next time make sure they include the SAI numbers.
Old Apr 28, 2004 | 11:15 PM
Sack Master's Avatar
Default Re: (Louie)
If a reputable shop did your alignment they would tell you your ball joints, tie rods, and bushings are whack. Usually they wouldn't align it until its fixed. Of course when the frame is all bent to crap most shops would tell you thats the problem. Take it to a better shop next time and they will tell you whats wrong with your car.
Old Apr 28, 2004 | 11:36 PM
mmuller's Avatar
Mad Scientist
Default Re: (Louie)
thanks everybody for your replay's.
I already know what is wrong with the car, sub-frame and right shock tower. What i was asking is a temporary fix for the alignment until i decide on what to do.
to Louie for pointing me in the right direction on how to align the car so the pull will be lessened.
sd619jef9
17
Nov 25, 2011 01:41 AM
h-o-n-d-a
Suspension & Brakes
Apr 18, 2010 07:40 PM
car noob
Nov 6, 2008 11:46 AM
bcrosby51
Sep 19, 2007 08:12 AM
ThatsMyEG
Jul 1, 2005 04:43 PM
