Why forced induction is better then NA.
Old Apr 26, 2004 | 06:45 AM
HamiltonRex's Avatar
Default Why forced induction is better then NA.
Im doing an 'persuasive essay' for english.
I have chosen to do my topic on 'forced induction is superior to a N/A engine build'
I need 3 main points WHY its better.
Heres what i got so far.
1. Turbo's can make more power
2. The power of a Turbo motor can be changed for the driving conditions
3. I 'think' you have better traction control with high HP from a turbo then a N/A.
Im am not here to argue why they are better or whatever, i just need some good points why there better, i know theres pro's and con's. Lets just think of the pro's right now .
I would like to get some information to help back up my points. If anyone on here who has built a 10 or 11 second turbo motor could please input their information, it would also help if the car was sponcered or someone who owned a company gave a good quote like "i will always turbo a motor instead of doing a NA build" so i can use the quote in my essay.
Thanks!
Old Apr 26, 2004 | 07:01 AM
Rollo Lawson's Avatar
Old Apr 26, 2004 | 07:14 AM
HybridKOOP's Avatar
Default Re: (B16C1)
Chicks dig the BOV.
Old Apr 26, 2004 | 07:22 AM
J337_UNIT's Avatar
Default Re: (HybridKOOP)
also you dont need to downshift to pass someone
Old Apr 26, 2004 | 07:32 AM
TheShodan's Avatar
Moderator
How about a real Response??
Turbos reuse the exhaust gases wasted by the motor in order to create more efficient engine utilization.
underpressure02's Avatar
Default Re: Why forced induction is better then NA. (HamiltonRex)
Just put this in your opening statement. You will get an A
NOS is like a Hot chick W/STD's, You wanna hit it, But your afraid of the consequences.
Old Apr 26, 2004 | 07:48 AM
Burke's Avatar
Banned
i just emialed you a powerpoint presentation and an outline i did 2 weeks ago
Old Apr 26, 2004 | 07:52 AM
EJ1 wilcox's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">How about a real Response??
Turbos reuse the exhaust gases wasted by the motor in order to create more efficient engine utilization.</TD></TR></TABLE>
This is what I was going to say...
Plus, because of the added oxygen mixing with the gasoline you get better combustion.
Just check out garrett's web site and look up turbo info on howstuffworks.com, they make plenty of good arguments about why turbos are cool
Old Apr 26, 2004 | 08:03 AM
Suprdave's Avatar
Default Re: (koreanwilcox)
Wow, seriously do some research before you want to be persuasive.
Old Apr 26, 2004 | 11:35 AM
Default Re: (Suprdave)
Thanks to thoes who are actually giving me good points
-Eric
Old Apr 26, 2004 | 12:19 PM
leadfoot78's Avatar
Default Re: (HamiltonRex)
Sounds to me like you don't know enough about turbos to write an essay about them. Look up Volumetric Efficiency, that will give you some material to write about.
Old Apr 26, 2004 | 01:55 PM
Default Re: (leadfoot78)
As far as the science behind a turbo, No i dont know much about them at all.
Its a 2 pg 5 paragrah essay double spaced. not long.
I learned a bunch from that howitworks.com site.
Its a gr11 english teacher, not a professor at a university.
-Eric
Old Apr 26, 2004 | 02:14 PM
RS Design's Avatar
drive one.... of each and you will automatically be enlightend
Old Apr 26, 2004 | 02:53 PM
dfoxengr's Avatar
i like NA better. its an opinion
Old Apr 26, 2004 | 03:25 PM
POLLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Im doing an 'persuasive essay' for english.
Thanks!</TD></TR></TABLE>
If you want to be 100% accurate scratch off #3 and think of another benefit, because that ain't right mo'flower.
Old Apr 26, 2004 | 03:36 PM
red91sit's Avatar
Default Re: Why forced induction is better then NA. (POLLO)
intercoolers are more pretty than a FMCAI lol.
Old Apr 26, 2004 | 03:54 PM
Kal's Avatar
Kal
yep. all that power makes the rubber spin like a ****
Old Apr 26, 2004 | 04:59 PM
TrueNorthStar's Avatar
Default Re: Why forced induction is better then NA. (Kal)
Because if you took a N/A motor that made the <U>same</U> amount of HP as a turbo motor, you would see that the turbo motor gets better gas mileage under normal driving conditions
Just dont tell them that the N/A motor gets better gas mileage when your foot hits the floor. (BSFC)
heh, how many people can make 400+hp and still get 30+mpg? (if you dont drive like a maniac)
Old Apr 26, 2004 | 06:03 PM
Default Re: Why forced induction is better then NA. (TrueNorthStar)
Alright ill see what i can come up with,
Thanks!
-Eric
Old Apr 26, 2004 | 06:15 PM
G
sh!t happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Chicks dig the BOV.</TD></TR></TABLE>
ahhahahahaah that is funny as ****.. just write that in the project//
efi2nr
Oct 16, 2006 04:29 PM
jmflyd
10
Nov 5, 2004 08:34 AM
93hatchin
45
Jan 30, 2004 11:13 AM
JBk24crx
Jun 8, 2003 11:15 AM
InfamousRS
Jan 16, 2002 06:17 PM
