e-brake
my e-brake light started coming on when i would get on the gas a little bit in first and 2nd and would go off usually when i hit 4th. now it just always stays on. when i first put the e-brake down it goes off but now when i drive its always on. i adjusted the e-brake because the cable felt a little loose but it dident help. any answers?
That light is not only for your e brake it is also for your brake fluid resevoir however it is spelled. But check to make sure that is full and there is probaly a button for the light on your ebrake toward the back of it, so when you pull it up the button gets activated and that button might be stuck.
alright sweet, i was wondering if it was just for the e-brake or what, my brake fluid is low, but still above the line. im gonna add some tomorrow and see if that fixes it. thanks yo.
shocker911
Oct 7, 2010 04:24 PM
